Author Topic: WeatherFlow Data on ROKU  (Read 3118 times)
Offline sjp0eqt
« on: February 14, 2022, 10:22:48 AM »
For those of you that have a WeatherFlow station and a ROKU streaming device on your TV, I have a cool display for you to try.
I developed a ROKU channel that will enable you to view WeatherFlow station data on your TV using your ROKU device (your station, or ANY WeatherFlow station sharing data publicly).
Please remember, this is not intended to be a scientific or analytical tool.
It is intended to simply take a peek at current weather statistics while surfing TV on a ROKU device.
On your ROKU device:
Home > Streaming Channels > Search Channels > “weatherflow data viewer”
Add the channel and follow the directions.
Screenshot
« Last Edit: February 14, 2022, 10:35:29 AM by sjp0eqt »
Re: WeatherFlow Data on ROKU
« Reply #1 on: February 14, 2022, 04:57:59 PM »
I don't have a Weatherflow station, but I did find a "Tempest by Weatherflow" map that has a station near me.
I couldn't find how to determine the station number so I can use this Roku app.
Any suggestions?
Offline sjp0eqt
« Reply #2 on: February 14, 2022, 05:16:33 PM »
YES, great question
  • When you select a station from the map, a tabular view of the data is displayed on the right.
  • Select the name of the station in the top yellow heading.
  • That will take you to the station specific webpage.
  • Look in the URL, it will contain the station number.  example: https://tempestwx.com/station/27685/
In this example the station's number is 27685
« Reply #3 on: February 14, 2022, 07:20:08 PM »
YES, great question
Thanks for the hint, works perfectly!
Offline sjp0eqt
« Reply #4 on: February 14, 2022, 07:27:19 PM »
Excellent, you can add multiple stations if there are other areas your interested in.
They will be added to the menu and you can select each station easily.
Offline PamG1
« Reply #5 on: May 25, 2023, 02:56:10 PM »
It went to v5 and I can't seem to get it to work. I don't own one of the weather flow machine buy was able to fin the weather code number near me. There are three. Moors mill, Bobo section rod and tanner rd in alabama. But they do t seem to reconize those now. I even try rebooting the app and re apply the app on roku. No didn't  want to work.  ](*,)Can you help.
Offline sjp0eqt
« Reply #6 on: May 25, 2023, 03:09:41 PM »
Man, you have the horrible luck of loading or trying my application as its having problems.
I published this stable version on 4/4/23 and as of Monday 5/22/23 it is not working.
I am troubleshooting and will update everyone as things progress.
Thank you for the interest in the application !!!
Offline sjp0eqt
« Reply #7 on: June 08, 2023, 05:45:18 PM »
Hey, the issue with the ROKU application for WeatherFlow data has been fixed !!
Please re-install or update the application.
Thank you again for the interest !!
« Reply #8 on: June 09, 2023, 08:03:52 AM »
Indeed it has! Thanks.
