Weather Related Organizations > WeatherUnderground
Wundergrounds API broke my previous method of getting weather data, any tools?
(1/1)
Deten:
Hi Folks,
I used to generate webpages using excel & the station I was looking at, to grab weather data for a specific day, then I would combine them all together to get a full year of weather info.
Now that they have implemented the API, this setup doesnt work. So now I have an API key, but I figure someone should already have a tool that lets me grab data like this without having to make it myself. I am not familiar with API, so I really hope that isnt going to be what I have to do :)
Any help?
saratogaWX:
You can use WXDailyHistory.php from https://github.com/ktrue/WU-History to have the API fetch data from WU and return in the CSV format that the WU WXDailyHistory.asp page used to return.
Deten:
--- Quote from: saratogaWX on July 12, 2021, 06:46:45 PM ---You can use WXDailyHistory.php from https://github.com/ktrue/WU-History to have the API fetch data from WU and return in the CSV format that the WU WXDailyHistory.asp page used to return.
--- End quote ---
Thank you, I looked at that, but in the "instructions" it says to upload to my website. But I am not doing this from a server/website, just my own computer. Do you know if there is a workaround?
saratogaWX:
The code is written in PHP, and that's usually found on a webserver. You just need to have a PHP interpreter installed (that includes curl library).
The easiest way to do that is to use an all-in-one bundle of Apache/PHP like XAMPP which makes your local system (Windows, MacOS or Linux) into a webserver with PHP capabilities. You can put the WXDailyHistory.php script in c:\xampp\htdocs directory, then run localhost/WXDailyHistory.php?... to fetch the data/return the CSVs you want.
I think it would be more difficult to just install a command-line version of PHP with the needed features .. the XAMPP program does it for you.
