Weather Software > WeeWX Software
Add additional soilMoist fields to database
(1/1)
TinkerTown:
I am runnin Weewx with the Belchertown skin and I just added a bunch of moisture sensors to my Ecowitt unit. I am having issues getting them to display in the skin and I looked in the database and I only see four fields for the sensors.
| archive_day_soilMoist1
| archive_day_soilMoist2
| archive_day_soilMoist3
| archive_day_soilMoist4
How can I add additional fields up to SoilMoist7?
I don't know much about database management, I was hoping someone would have the commands to enter to add 5,6,7.
SnowHiker:
Back up your database in case it doesn't work the way you expect, then try:
--- Code: ---wee_database --add-column=soilMoist5
--- End code ---
--- Code: ---wee_database --add-column=soilMoist6
--- End code ---
--- Code: ---wee_database --add-column=soilMoist7
--- End code ---
More info here:
http://www.weewx.com/docs/utilities.htm#wee_database_utility
TinkerTown:
I got it, thank you! I thought I saw somewhere that said you could do that, but my search skills are apparently not that great! That worked, got them up and running, thanks!
Gyvate:
EDIT: removed as the OP got a solution working ....
Gyvate:
