Weather Software > RaspberryPI Weather Software
433MHz RF to USB anyone?
<< < (2/9) > >>
uwemundry:
That is grand!!! What a great step for mankind  :-)
I ordered the sdr. Will keep you posted.
Thank you so much for your response and info!
UM
uwemundry:
I have the SDR (based on Rafael Micro R820T tuner) and running rtl_433 v20.11-55. The output I get from my Atlas can be seen in attached screenshot. There is no air pressure in the output. Is there a version of rtl_433 which decodes that as well?
Thank you!
Storm017:
The sensor for the pressure is located in the console, so RTL_433 will not decode the pressure. It will only decode what is being sent from the outside sensors. If your console has an micro-USB connector you can interface the console to the RPI to capture all the data.
uwemundry:
Mmhhh, I have the Indoor Display for the Atlas (model 06061). It has a micro USB connector, but nothing happens when I plug that into the PC. I guess it needs a special driver. Or has anyone figured out how to use that port?
What is RPI?
Thank you!
Storm017:
RPI is a Raspberry PI a single board computer. https://www.amazon.com/CanaKit-Raspberry-Power-Supply-Listed/dp/B07BC6WH7V
[#] Next page
[*] Previous page
