Weather Station Hardware > Blitzortung
Blitzortung question
(1/1)
nincehelser:
If I'm understanding Blitzortung correctly, it seems it works best as part of a network, correct?
My question is how well it reports things locally on its own.
Say, for example, a storm or disaster has knocked out my Internet access.  Will I still get useful data?
George
DanS:
Doesn't that system rely on other Blitzortung users that are on the Internet so your system can triangulate and plot a storm's position against their data? Any Blitzortung system (configured per instructions) alone would detect the lightning but would not be able to determine distance and direction accurately without the other on-line stations.
Hope this is the system you're talking about and if not I apologize.
miraculon:
Blitzortung does not attempt to determine distance on its own.
They explain this on http://www.blitzortung.org.
It requires "participation" of four stations for the strike to be mapped on the system. Here is a good explanation of why four stations are required: http://www.scalar.si/en/index.php?option=com_content&task=section&id=23&Itemid=71
Otherwise, the Yellow LED and waveform display are the only local indications of a strike (or noise).
