Author Topic: ecowitt Feels like temp  (Read 631 times)
Offline Platokidd
  • top side land of Lincoln
« on: August 06, 2022, 07:49:24 AM »
Just noticed the feels like temp no longer works / shows up on all my ecowitt consoles and apps.
 [ You are not allowed to view attachments ]  [ You are not allowed to view attachments ]
« Last Edit: August 06, 2022, 08:13:10 AM by Platokidd »
Ambient
1-WS-5000 1-WS-2902A 2-WS40/RAIN 1-WH31L
1-METEOBRIDGE 1-PM2.5 (WH41B) 3-WH31 1-SRX100LX
ECOWITT
2-HP2550 2-HP2560 2-GW2000 2-GW1100
2-WS68 1-WS80 1-WH32EP 10-WH31 1-WH40
1-HP10 2-WH45 4-WH55 5-WH51
1-WN30 1-WH41
1-DAVIS 7714
1-STRATUS
1-Fisher Barometer 1436R-22
PWS at 2 locations.
1- Storm Sensor-Zelda the dog ;)
Online Rover1822
Re: ecowitt real feel temp
« Reply #1 on: August 06, 2022, 08:07:17 AM »
You mean the feels like? On my consoles it doesn't change away from the current temp until it is over 80F
Or did I miss what you are showing?
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
  WittBoy WS90 + GW2000
  WS90 (other one) + GW1100
Personal Sites: Weather Cam
Offline Platokidd
« Reply #2 on: August 06, 2022, 08:19:14 AM »
Yes, corrected my post.
Should have taken the picture earlier in the day when it was above 80. (Restarted the console so high temp is not true)
Will have to see if it changes today as its going to be HOT here today.
So it's above 80 and below what temp?
Ambient
ECOWITT
1-WN30 1-WH41
1-DAVIS 7714
1-STRATUS
PWS at 2 locations.
Online Rover1822
« Reply #3 on: August 06, 2022, 08:22:24 AM »
I've only noticed the above ~80F , not aware of the upper limit.
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
Offline Platokidd
« Reply #4 on: August 06, 2022, 08:28:34 AM »
Thanks. Thought for sure is showed up more. Not a true real feel showing., Thought it might have been from the last firmware update.
Ambient
ECOWITT
1-WN30 1-WH41
1-DAVIS 7714
1-STRATUS
PWS at 2 locations.
Online Rover1822
Re: ecowitt Feels like temp
« Reply #5 on: August 06, 2022, 08:33:34 AM »
I just checked wikipedia, and the NOAA chart they have starts at 80F/27C
WU apparently applies the equation at a lower temps than does the consoles and apps
What is interesting on the console, is when it breaches the 80F the Feels Like temp jump can be pretty interesting depending on humidity (we always have high humidity here)
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
Online Rover1822
« Reply #6 on: August 06, 2022, 08:40:55 AM »
If you look your the 24hr graph for temp on Ecowitt.net, you should see the "feels like" separate from the temp at 80F, if the factors warrant it.
As opposed to waiting for it get hot :)
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
Online Rover1822
« Reply #7 on: August 06, 2022, 11:19:08 AM »
Yep I just crossed the 80F mark to 82.1 , and the feels like jumped from just ~80F, to 89.5F in matter of minutes. Amazingly it did not "feel like" a 9F jump :)    (Humidity is roughly 80%)
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
