Author Topic: My Saratoga / Weather-Display template site not current as of 1/23/2021  (Read 1051 times)
Offline mstan
My site http://newmiddletownweather.com was working fine I didn't touch it but now seems to have stop updating. I checked WD and FTP seems to be uploading fine. Not sure where to start. WD, The Templetes, or My Web Host.
« Last Edit: February 03, 2021, 11:25:57 AM by mstan »
Offline wvdkuil
  • Wim van der kuil
Re: My Saratoga / Weather-Display template site not current as of 1/23/2021
« Reply #1 on: February 03, 2021, 10:46:49 AM »
My site NewMiddlwtownWeather.com was working fine I didn't touch it but now seems to have stop updating. I checked WD and FTP seems to be uploading fine. Not sure where to start. WD, The Templetes, or My Web Host.
The correct link to the site.  http://newmiddletownweather.com/
http://newmiddletownweather.com/check-fetch-times.php?show=wx
shows that WD is not uploading the testtags.php
Check in the W/webfiles folders
==> if there is a testtags.txt (which WD uses to build the testtags.php)
==> and what the date-times are of those files
Check your webserver what the data-time is of the testtags.php there
Wim
Offline mstan
« Reply #2 on: February 03, 2021, 11:18:12 AM »
Hi, Thanks for the help. testtags.php is being updated in WD and my webhost has the current date and time of the file.
Offline wvdkuil
  • Wim van der kuil
« Reply #3 on: February 03, 2021, 11:22:41 AM »
Please check the testtags.txt  contents
Does it contains the %xvxvxv% tags or is it a exact copy of the contents of testtags.php ?
Wim
Offline mstan
« Reply #4 on: February 03, 2021, 11:30:04 AM »
tags
Offline wvdkuil
  • Wim van der kuil
« Reply #5 on: February 03, 2021, 11:50:53 AM »
tags
Check:
The testtags.txt in the WD folder only contains %xxxxx% values
The testtags.php in the WD folder has old data   from Jan 21
If both "yes" then WD is in error, needs restarting?
Check 2:
The testtags.txt in the WD folder has %xxxxx%
The testtags.php in the WD folder has correct data   from today
http://newmiddletownweather.com/testtags.php?sce=view  shows old data  ==> Yes
The filetime of http://newmiddletownweather.com/testtags.php is from today
If all four is "yes" then ?????
I assume another person is needed.
Wim
Offline mstan
« Reply #6 on: February 03, 2021, 11:57:26 AM »
Yes on all 4.
Offline wvdkuil
  • Wim van der kuil
« Reply #7 on: February 03, 2021, 12:09:06 PM »
Yes on all 4.
As none of the data-files on oyur website is current http://newmiddletownweather.com/wxstatus.php  this seems more complex tyhan a mis-communication between Wd and your server
Also the status shows
Weather-Display FTP   NOT Current   273:11:22   > 0:05:15   Sat, 23-Jan-2021 2:50am EST
Weather-Display weather data   NOT Current   273:11:59   > 0:05:15  Sat, 23-Jan-2021 2:50am EST
It tells us that the testtags.php contents is from Jan 23 and the file itself is also from Jan 23.
Are you sure you are looking to the correct files for newmiddletownweather.com?
Maybe you are looking to a different website.
Did you use your FTP program to newmiddletownweather.com and did you look into the testtags.php with the correct filetime of today?
Did it contain data of today?
The only current data on this site is
NEXRAD Radar KCLE status: Active [last data 0:07:06 h:m:s ago] as of Wed, 03-Feb-2021 12:00pm EST
Wim
Offline mstan
« Reply #8 on: February 03, 2021, 12:26:40 PM »
Yes that's what I did. The file testtags.php is there with the correct date and contains current data. Like I said I didn't change anything it just stopped working. I wonder if the webhost changed something they switched from cpanel to something else just recently.
Offline wvdkuil
  • Wim van der kuil
« Reply #9 on: February 03, 2021, 12:56:16 PM »
Then  we are looking at different sites
This is the internal path   of your current website /home/u519-169ikkxehi64/www/newmiddletownweather.com/public_html
That is checked by  http://newmiddletownweather.com/check-fetch-times.php?show=wx
Probably you, your WD program and your FTP program are looking at totally different sites.
When going from and very old site to a new cPanel website all your FTP settings are changed.
Your site is nearly always moved to another server by the provider. Probably the IP-address changes also.
Contact support at your provider and ask the current  FTP settings.
Maybe you can find them yourself at the cPanel pages also.
Compare those settings with the ones you use in WD and your FTP program.
Wim
« Last Edit: February 03, 2021, 01:02:43 PM by wvdkuil »
Offline mstan
« Reply #10 on: February 03, 2021, 02:23:01 PM »
I got it! Wow it all started on the 23 thats when siteground moved away from cpanel to something else...well what the did was separate all the sites under your account I use to log in on my main site and all my other websites were in a directory under that...what else they did was not move ftp accounts that you had set up to the sites under your main account...so yes you were right i was logging into the main account and WD was logging into another that wasn't there. Yikes! Thanks for all your help!
