I'm considering moving away from my Meteostick + Pi setup, because it's not terribly stable and reception is poor.
The big advantage I have now, is that the Meteostick is connected to a Raspberry PI with battery backup. I've coded the Pi to cache any updates it cannot post to the server (in case of internet or power failure).
Pretty much like the WeatherLink does in such cases. It will broadcast the data to the Davis servers after power/internet has been restored.
My question: Will the Weatherlink behave in the same way with the local broadcast requests? That is, if you request the WeatherLink to broadcast to a local IP adress for 24 hours, and the power is out for 1 hour, will the WeatherLink also attempt to rebroadcast the data during that time to the local IP, or only the Davis servers?
