Author Topic: Colorado Station  (Read 2257 times)
Offline prsmith777
Colorado Station
« on: November 10, 2022, 03:07:46 PM »
This is my setup.
I have the Ambient WS5000 about 30ft up on the pole.  I added a box at the base to put in the heater transformer and a plug.  The pole tilts down for easy access.
« Last Edit: November 10, 2022, 03:09:52 PM by prsmith777 »
Offline MchWxEnthusiast
  • That Guy
  • Nothing Much
Re: Colorado Station
« Reply #1 on: November 11, 2022, 01:54:05 PM »
How are you gonna do maintenance on that?
Weather Radio Freq: 162.475 MHz
Weather Radio Loc:  Plainwell, MI
Transmitter Call Sign: WWF34
Streaming Status: NN
« Reply #2 on: November 11, 2022, 04:38:22 PM »
I can see the anny at 30ft. That's a good idea, but can you mount the temperature sensor lower or is is it all one unit.
Offline WheatonRon
    • WUnderground
« Reply #3 on: November 12, 2022, 01:53:42 PM »
Can’t tell from the photo but is your rain collector up that high? If so, you get more accurate measurements if placed on or near the ground. As another poster stated, how are you going to perform routine maintenance on this?
Offline TheBushPilot
  • Calibration Technician
« Reply #4 on: November 13, 2022, 07:07:40 PM »
Looks like he's got a tilting mechanism for maintenance. Can see it better in the second image as well.
Really cool siting and setup, did you make that mast system yourself?
"There is — always — more than one thing influencing anything we are trying to measure." ~ Sherman Fredrickson
"Do it right or don't do it at all."
Met Instruments Project
Central Chasers
« Reply #5 on: November 14, 2022, 09:24:50 AM »
It looks like the DX Engineering "Omni-Tilt" Vertical Antenna Base. I have one mounted for my 5-Band Vertical Ham HF antenna. It appears to have been painted, but I recognized it immediately.
Go to DX Engineering's web site and look up "Omni-Tilt".
Offline TinkerTown
« Reply #6 on: January 04, 2023, 07:12:36 AM »
That would be awesome for your wind readings. I would move the rain collector closer to the ground, maybe a foot above your tilting point on the pole. I would put my temp reader about six feet off that pole for optimal readings. But hell, it's better than my all in one units placement so those are just suggestions since you have the pole set, nice rig.
Ecowitt GW1000 | WS-2902C |Weewx on Raspberry Pi
WU: KNMLOVIN14  |  PWSweather: PWSLOVNM1
CWOP: FW9112; https://lovingtonweather.com
