Author Topic: Personal Weather Tablet - An Android tablet app to show your GW1000 data  (Read 25807 times)
Offline mooseo
Re: Personal Weather Tablet - An Android tablet app to show your GW1000 data
« Reply #300 on: December 01, 2022, 10:59:50 AM »
PWT suddenly stopped working... it's been sitting here on my desk working perfectly for months. Then at 6:30 yesterday morning, it suddenly stopped receiving data. Ecowitt.net is still getting data from my GW1000, so it's not that.
I've rebooted the tablet a few times, unplugged and replugged the GW1000 a few times. I've checked the router and none of the IP addresses have changed. Any suggestions?
Offline Gyvate
« Reply #301 on: December 01, 2022, 11:02:48 AM »
visit https://ear.phantasoft.de
read the instructions
and verify if your console (GW1000) is posting there.
Then come back with the results.
Do you have the latest GW1000 firmware installed ? (1.7.5)
EDIT: corrected URL from .com to .de ](*,)
« Last Edit: December 01, 2022, 04:07:08 PM by Gyvate »
Offline Vasco
    • PWS
« Reply #302 on: December 01, 2022, 12:10:41 PM »
visit https://ear.phantasoft.com
Think that should be https://ear.phantasoft.de  :?:
And I think the first line of the instructions should read:
"You just have to configure the custom server function of your own weather station with following settings via WS View (Android, iOS), WSView Plus (Android, iOS) or the web interface of the device:"
« Last Edit: December 01, 2022, 12:32:16 PM by Vasco »
Offline Gyvate
« Reply #303 on: December 01, 2022, 04:09:36 PM »
.de is correct - corrected in my earlier post
the other I cannot tell as the site shows the text in the language which corresponds to my locale
and anyhow WS View Plus should be the app of choice and no longer the legacy WS View app
Offline olicat
  • GWxx00, HPx5x1C, WN1900C, WN1980C & WS3xx0C
    • FOSHKplugin
« Reply #304 on: December 01, 2022, 04:18:35 PM »
Hi!
via WS View
Thanks. Somehow the name of the app was going lost. Fixed.
You may switch the language by clicking the DE/EN link in the bottom line.
Oliver
Offline mooseo
« Reply #305 on: December 02, 2022, 01:45:07 AM »
Thanks for the thoughts. I am running the 1.7.5 firmware. It seems to be reporting to the autoresponder (last lines below).
I do struggle to connect to it through my local network on WS View. If I want to access the configuration, I have to turn on the internal wifi server. If I try to connect directly through the web browser to its IP address, I get "Refused to connect" but I can ping it, so it is active.
PASSKEY=7C8E6A7E3E2270BB72CF3C04CA0EB84D&stationtype=GW1000B_V1.7.5&runtime=714&dateutc=2022-12-02 06:33:29&tempinf=67.46&humidityin=44&baromrelin=29.949&baromabsin=30.032&tempf=39.02&humidity=94&winddir=9&windspeedmph=0.45&windgustmph=1.12&maxdailygust=6.93&solarradiation=0.00&uv=0&rainratein=0.000&eventrainin=0.000&hourlyrainin=0.000&dailyrainin=0.000&weeklyrainin=1.177&monthlyrainin=1.169&yearlyrainin=2.398&totalrainin=2.398&temp1f=56.84&humidity1=57&temp2f=65.48&humidity2=50&temp3f=68.00&humidity3=49&pm25_ch1=6.0&pm25_avg_24h_ch1=6.0&pm25_ch2=10.0&pm25_avg_24h_ch2=10.0&wh65batt=0&batt1=0&batt2=0&batt3=0&pm25batt1=6&pm25batt2=5&freq=915M&model=GW1000B_Pro
Offline olicat
    • FOSHKplugin
« Reply #306 on: December 02, 2022, 01:54:40 AM »
Hi!
This sounds like a problem of your internet router/firewall.
Some routers have a setting option to activate network access in the internal network. Without this setting, the devices in question can communicate with the outside - with the Internet. However, they cannot communicate with other devices in the internal network.
In any case, I would check the settings on the router. Because basically - to the outside - everything works.
Perhaps a user can help you if you tell us which router you are using.
Regards, Oliver
Offline mooseo
« Reply #307 on: December 02, 2022, 02:17:02 AM »
Thanks! Yes, I had a bunch of problems when I first got a new router (ASUS RT-AX88U). But eventually I got it all sorted and it was working fine for months. Until yesterday when it just stopped.
Good point about the isolation within the LAN. I think I found a setting like that, but it was turned off. Would love to know if others have had this problem.
UPDATE: I never truly figured out why I got this problem, but based on these suggestions I set up a separate guest network within my router (only enabled the 2.4 Ghz band), put both the tablet and the GW1000 on it, and now everything is working.
« Last Edit: December 03, 2022, 02:00:40 PM by mooseo »
Offline v1pr
is it possible to have multiple temperature/humidity data in one graph (with different colors)? It would be also good, if I can set the Y step of the graph (it's too tight for me know on a 10" tablet)
Offline olicat
    • FOSHKplugin
« Reply #309 on: April 04, 2024, 08:42:55 AM »
Hi!
That was to be expected. Sadly.
Now Personal Weather Tablet (PWT) has disappeared from the Play Store - so it can no longer be downloaded and installed.
Unfortunately the author of PWT @Da9L has not responded to any of my enquiries (over years!). He hasn't been here in the forum for a very long time either. I hope he's well.
So we have to assume that that's it for this great programme.
Surely you could install PWT via sideload - if you have the APK for it. Unfortunately, I cannot assess the legal situation as to what extent someone is allowed to offer the APK for download. Also, and above all, because it is/was actually a paid app. Of course, this also makes (prevents?) the search for the APK more difficult.
But maybe someone can still find the APK for download somewhere on the net?
Perhaps someone would like to try their hand at a new development? I see a market.
Regards, Oliver
Offline Gyvate
« Reply #310 on: April 10, 2024, 02:34:59 AM »
there is an APK for version 1.4.1 (last upgrade) - PM
