Author Topic: API Weatherlink live  (Read 453 times)
Offline ich74
« on: March 10, 2024, 05:46:01 AM »
Hello,
I'm having an issue with API query with Weatherlink.
The following is displayed:
“Call timestamp parameter “t” is deprecated. The timestamp you specify must be within a range that is plus or minus 300 seconds of the API server's internal clock."
what is wrong? Thanks
There is 9:50 but in really its 10:50
« Last Edit: March 10, 2024, 05:53:14 AM by ich74 »
Offline mcrossley
    • Wilmslow Astro
Re: API Weatherlink live
« Reply #1 on: March 10, 2024, 06:22:24 AM »
The "t" parameter (which as the API says was deprecated some time ago, read the API docs for the new, much simpler way of calling the API) is a UNIX timestamp, so represents a UTC time. It sounds like you are sending local time masquerading as a timestamp?
Offline ich74
« Reply #2 on: March 10, 2024, 06:29:23 AM »
hello,
i taked this:
https://api.weatherlink.com/v2/stations?api-key={YOUR API KEY}
is there a better way?
Offline johnd
« Reply #3 on: March 10, 2024, 06:33:35 AM »
Are you looking at old documentation somehow? The old signature is no longer necessary at all. And there is no time element in the call to the /stations endpoint. But you do need to pass x-api-secret in the header (but not as a query parameter)
Cambridge UK
Offline ich74
« Reply #4 on: March 10, 2024, 06:34:52 AM »
Offline johnd
« Reply #5 on: March 10, 2024, 06:38:31 AM »
i am looking here
https://weatherlink.github.io/v2-api/tutorial
But that does not say anything about a time parameter. (Maybe you are not sending any time value, but it's merely a misleading error message?) It says:
To make the API call to the /stations API endpoint you need to make an HTTP GET API call to the following URL and include a header named X-Api-Secret set to the value of your API Secret.
« Last Edit: March 10, 2024, 06:57:45 AM by johnd »
Cambridge UK
Offline ich74
« Reply #6 on: March 10, 2024, 07:27:29 AM »
yes, i copied in my key and secret. think the problem ist, that the station have an other time than the real time. there is a difference von one hour
Offline wvdkuil
  • Wim van der kuil
« Reply #7 on: March 10, 2024, 07:40:39 AM »
There is no need anymore to use the t=value parameter.
It still works and I assume entering a wrong value, such as local time,  will make the URL invalid.
But if you use the t=value   you should make sure to use the UTC-time-value
Not your local clock value in Germany which is indeed 1  hour earlier then the UTC time.
The URL as it is used currently:
https://api.weatherlink.com/v2/current/111111?api-key=_API_SETTING_The header for this URL:
X-Api-Secret:_secret_I assume you are reading an old version of the API-documentation.
Attached a screenshot of how it should look today.
Wim
« Last Edit: March 10, 2024, 07:47:52 AM by wvdkuil »
Offline ich74
« Reply #8 on: March 10, 2024, 07:47:48 AM »
this is my url
https://api.weatherlink.com/v2/current/{station-id}?api-key={YOUR API KEY}
i fill out id and key
« Last Edit: March 10, 2024, 07:52:55 AM by ich74 »
Offline wvdkuil
  • Wim van der kuil
« Reply #9 on: March 10, 2024, 07:54:24 AM »
this is my url
But did you include the "secret" value in your header when sending the URL?
X-Api-Secret:_secret_Please post the exact code lines you are using so we can take a look.
Wim
Offline mcrossley
    • Wilmslow Astro
« Reply #11 on: March 10, 2024, 07:58:23 AM »
Are you just putting that URL into a browser?
If so, you cannot do that, you need to set a header in the GET that is sent to server, you will need to do that in code, or by using something like "curl" on Linux.
Offline ich74
« Reply #12 on: March 10, 2024, 08:01:45 AM »
The background is that I need a URL from which the Davis data can be retrieved remotely. thought this could be done with api
Offline wvdkuil
  • Wim van der kuil
« Reply #13 on: March 10, 2024, 08:05:08 AM »
Yes, it can but not in a browser directly.
Only with a small script on your webserver.
Offline ich74
« Reply #14 on: March 10, 2024, 08:06:48 AM »
oK. Thanks. I won't be able to do that then. Thanks anyway
Offline johnd
« Reply #15 on: March 10, 2024, 08:10:18 AM »
The API works fine but it is intended for access to the weatherlink.com data by programs that you have written. As Mark says, you cannot use the URL directly in a browser.
If you want a simpler tool to use then you could try Postman or, if you are using Visual Studio Code as your code editor then the Thunder extension works well - personally I prefer Thunder.
Cambridge UK
Offline mcrossley
    • Wilmslow Astro
« Reply #16 on: March 10, 2024, 06:20:44 PM »
But Davis do supply a Postman collection to get you going with the basics quite quickly.
Offline johnd
« Reply #17 on: March 10, 2024, 07:02:57 PM »
Sure, Thunder is actually pretty similar but simpler IMO, so it's fairly easy to copy the Postman settings across to Thunder. But sure either will do fine.
Cambridge UK
