Author Topic: SSL/TLS issue causing intermittent "Security Issue" Error  (Read 983 times)
« on: May 02, 2025, 09:35:25 AM »
I have been having a struggle with my web site for several days. The site previously worked fine, but began issuing the SSL related "HTTP Strict Transport Security" (HSTS) error a few days back. It comes and goes, https://www.rogerscityweather.com was working OK until early this morning:  Fri, 02-May-2025 5:34am EDT.
I spent a lot of time on the hosting support chat (which I suspect is just a bot) that recommended a bunch of things that I tried. It is difficult to tell whether they worked or not since the problem comes and goes.
My alternate "site" URL http://www.rcwx.tech works OK. It is basically a redirect of the rogerscityweather.com site. Interestingly, the SSL/TLS page on the Cpanel shows both domains/sites under the same Certificate.
 autodiscover.rogerscityweather…com
 cpanel.rogerscityweather.com
 cpcalendars.rogerscityweather.com
 cpcontacts.rogerscityweather.com
 mail.rcwx.tech
 mail.rogerscityweather.com
rcwx.tech
 webdisk.rogerscityweather.com
 webmail.rogerscityweather.com
www.rcwx.tech
I gave up with the "tech support" and edited the site heavily to work around this problem.
I suspect that there is something going on with the SSL Certificate renewal that is automatically refreshing periodically causing this problem. I have run my site with Hosting24 for years with no issue. In the past, their support was good, but this time not so much.
I had to significantly change my site to eliminate a lot of regular Saratoga Scripts features in order to get something to work.
I would like any suggestions, or approaches to try with the "support" in order to get this resolved. I don't like what I had to do, but I'm between a rock and a hard place here.
Re: SSL/TLS issue causing intermittent "Security Issue" Error
« Reply #1 on: May 02, 2025, 10:16:15 AM »
They responded when I posted an "unfavorable review".
They fixed the site not loading, but meteohub doesn't like their force HTTPS solution.
HTTP Upload: 2025-05-02 10:07:36 Error: 2025-05-02 10:07:33 https://www.rogerscityweather.com/conds.php?d=02/05/2025,10:07:33,5.6,97,5.2,1.4,1.4,337.0,0.0,0.5,1006.9,337.0,1,m/s,C,hPa,mm,--,1005.7,27.2,205.0,26.7,19.0,13.0,4.7,6.2,6.5,20250502092119,4.2,20250502002418,4.1,20250502091800,6.2,20250502091638,1006.9,20250502100625,1000.9,20250502004109,6.1,15518,4.7,--,--,0.5,--,76.0,332.0,0.3,--,D,--,332.0,--,m,--,14:22,--,--,1.4: HTTPS support not compiled in. (no more tries)
« Reply #2 on: May 02, 2025, 10:35:10 AM »
Strangely, when I added the same string to another HTTP item in meteobridge with a 15 second upload interval, it started working..
 :-k
Offline Otis
  • (aka Paul)
    • Lake Huron Weather
« Reply #3 on: May 02, 2025, 03:08:11 PM »
Hey Greg, right now when I try to access the rogerscityweather site it is blocked by my security software, Bitdefender.  I have only been using Bitdef a few months now so that issue could be on my end?  Anyway, it blocks the site as "suspicious".
The rcwx site loaded okay, took a long time but it did load.
Edit:  this is what I get from Bitdefender.
Suspicious page blocked for your protection
Your connection to this web page is not safe due to an unmatching security certificate.
This means that the certificate was issued for a different web address than the one it is being used for, and you run the risk of exposing your data by accessing this page.
« Last Edit: May 02, 2025, 03:11:11 PM by Otis »
CW3699
Offline Vasco
    • PWS
« Reply #4 on: May 02, 2025, 03:17:07 PM »
Blocked by Edge, too. . .
« Reply #5 on: May 02, 2025, 03:24:54 PM »
 :-k
This didn't last. Back to the same old problem.
« Reply #6 on: May 02, 2025, 03:27:21 PM »
I think that something is periodically being overwritten at Hosting24 on the server. It comes and goes, works, then doesn't.
