Author Topic: AVAILABLE TO TRY - Android App Build for Weather Display  (Read 3613 times)
Offline CNYWeather
    • CNYWeather
« on: May 01, 2025, 06:48:07 PM »
I've been working on an Android App for my website. I use Weather Display software and have since 2006.
It's been a fun build. Its pretty simple I guess. Uses testtags.php and clientraw.txt files from WD.
Taken a bit more than i thought to build it. I too am using Cursor AI and I'm using Android Studio.
It's a Flutter build within Android Studio. Building an Android App APK is pretty simple.
An iOS all isnt right now.
I have testtags updating on app load, then the quickupdates kick in using clientraw.txt which I upload every 30 seconds.
It's still a work in progress, but my goal will be to create some kind of config file for everyone else to input their
paths to testtags and clientraw, their local NWS Office, local radar, and NWS alert zone and counties for the app to check.
It's up on Github now but not complete just yet. There's a few screenshots to share with you all. I'll keep working on it
and share once I get the app so everyone can customize it. Soon I hope.
« Last Edit: May 14, 2025, 01:54:02 PM by CNYWeather »
Tony
Re: Android App Build for Weather Display
« Reply #1 on: May 01, 2025, 10:31:15 PM »
Keep us posted
Offline vinesweather
    • The Vines Weather
« Reply #2 on: May 01, 2025, 11:11:52 PM »
looks great!
Offline jaltman
    • Stanley Rapids Weather
« Reply #3 on: May 02, 2025, 07:02:35 AM »
It looks very nice.  Please let us know when its available to install through the usual channels.
Jim
Offline CNYWeather
    • CNYWeather
« Reply #4 on: May 02, 2025, 11:37:59 AM »
anything else anyone can this to be implemented?
Tony
Offline swright1957
    • Hytheweather.co.uk
« Reply #5 on: May 03, 2025, 11:04:58 AM »
will this pick up info from any weather station like mine when available?
"anything's possible with the weather"
Offline CNYWeather
    • CNYWeather
« Reply #6 on: May 03, 2025, 12:04:40 PM »
It's built for Weather Display and uses testtags and clientraw. My goal is for it to be user configurable to put paths to those you upload, so it will display your data then.
Tony
Offline Meteoensevilla
    • Meteoensevilla
« Reply #7 on: May 06, 2025, 07:17:55 AM »
I'm looking forward to it. It would be great if it worked as a widget for Android.
Offline CNYWeather
    • CNYWeather
« Reply #8 on: May 14, 2025, 01:53:09 PM »
If anyone wants to give this a try, it's up on Github now.
https://github.com/trophyguy/CNYWeatherAppTemplate
You'll have to download the zip, extract, and manually install this on your phone.
This is an Android App for users of Weather Display Software.
As long as you're FTP'ing testtags and clientraw, you should be able to use this.
Bottom navigation bar you'll have a Config link.
You will need to fill in all the needed data/paths:
  • Name Your App
  • path to your testtags
  • path to clientraw
  • input your Lat and Long for forecast data
  • testtags update interval minutes
  • clientraw update interval seconds (called QuickUpdates in the app)
  • add multiple zones/county codes for warnings
  • add local weather radar code
I've never done this before. So let me know what I have messed up
or what can be improved upon. Thank you!
« Last Edit: May 14, 2025, 01:54:58 PM by CNYWeather »
Tony
Offline Fox_Of_The_Wind
  • Hi there!
    • http://www.desotowiwx.com
« Reply #9 on: July 01, 2025, 09:32:32 AM »
  • Name Your App
  • path to clientraw
Silly (and probably stupid) question how does one go by installing your app on a phone? If you can send me the right way for reading I will be willing to do some reading to fig it out.
Anthony
Offline swright1957
Re: AVAILABLE TO TRY - Android App Build for Weather Display
« Reply #10 on: July 02, 2025, 06:30:29 AM »
Hi
Does this only use testtags and clientraw or can you use just Clientraw???
Offline CNYWeather
    • CNYWeather
« Reply #11 on: July 03, 2025, 06:55:35 AM »
  • Name Your App
  • path to clientraw
No, not a silly question.  You can download the zip file, extract it, then either upload it to a cloud service like Google Drive, and install the APK frome there. Or you can connect your phone to your computer and upload it to your phone that way and install it that way.
Tony
Offline CNYWeather
    • CNYWeather
« Reply #12 on: July 03, 2025, 06:57:08 AM »
Hi
Yes, you can use just clientraw. The data may be old on app opening until the clientraw quick updates kick in.
Tony
Offline jaltman
« Reply #13 on: July 03, 2025, 07:15:14 AM »
Perhaps i am missing something, is there a prebuilt apk in the repository or does one have to build it?
Jim
Offline CNYWeather
    • CNYWeather
« Reply #14 on: July 03, 2025, 07:31:43 AM »
I guess thats my mistake. Seems you have to build it with Android Studio. I'll have to see if I can build the apk and post that in github.
Tony
Offline jaltman
« Reply #15 on: July 03, 2025, 07:44:53 AM »
Great, thanks. I used to have Android Studio installed and i actually knew how to use it, but its been so long...
Regards,
Jim
Offline CNYWeather
    • CNYWeather
« Reply #16 on: July 03, 2025, 07:53:26 AM »
Sorry, i'm still new to this.
try this: https://github.com/trophyguy/CNYWeatherAppTemplate/releases/tag/V1.2.0
Thats the apk for the app. At least I think I did it correctly.
Tony
Offline jaltman
« Reply #17 on: July 03, 2025, 07:55:41 AM »
Got it!  Thanks, i will try and side load it later and let you know of my outcome.
Jim
Offline jaltman
« Reply #18 on: July 03, 2025, 08:29:34 AM »
Its installed, but i don't seem to have a config.  Its working and showing me your weather. Don't see how to point to my weather station or set my zone for alerts.
Jim
Offline CNYWeather
    • CNYWeather
« Reply #19 on: July 03, 2025, 04:02:32 PM »
i'll have to look. I had a couple versions of it where it can be configured also and one for me.
I must have built the wrong one. I'll do it in the next couple of days. Sorry.
Tony
Offline jaltman
« Reply #20 on: July 03, 2025, 04:09:03 PM »
No problem, it looked great for everything i could see, but of course, would prefer to see my data. No rush, enjoy the holiday.
Jim
Offline jaltman
« Reply #21 on: July 09, 2025, 06:53:10 AM »
Don't forget us now, i love the app and would like to point it to my data.
Jim
Offline CNYWeather
    • CNYWeather
« Reply #22 on: July 10, 2025, 07:23:48 AM »
Tony
Offline jaltman
« Reply #23 on: July 10, 2025, 07:31:12 AM »
That's still the version that has no config to point it to my files.
Jim
Offline CNYWeather
    • CNYWeather
« Reply #24 on: July 10, 2025, 07:58:13 AM »
Sorry. Quite new at this.
https://github.com/trophyguy/CNYWeatherAppTemplate/releases/tag/v1.2.1
I dont this the advisories are working now. just wanted to note that.
Tony
