Author Topic: wxsoil with php 8.3  (Read 2412 times)
Offline ALITTLEweird1
  • Mark
    • North Bend Weather
wxsoil with php 8.3
« on: February 22, 2025, 06:10:23 PM »
My wxsoil script stopped working when I updated to php 8.3. I have all Zeros on my page.
The latest version I found and running is... // Version 1.03 ALPHA 15-SEP-2012 - Initial Version 1 release
Anyone else have this script working with 8.3?
I know my sensors are working because I got data showing here. https://www.northbendweather.com/wxsoiltempdetail.php
https://www.northbendweather.com/wxsoil.php
« Last Edit: February 22, 2025, 06:15:01 PM by ALITTLEweird1 »
Software: WeatherDisplay
Hardware: Davis VP2 + VP2 Solar + VP2 UV + Lightning Detector + Reolink Webcam + Soil temp + Soil Moisture
Offline hcorrin
    • Ballaugh Weather
Re: wxsoil with php 8.3
« Reply #1 on: February 23, 2025, 05:53:48 AM »
Try adding
error_reporting(E_ALL ^ E_NOTICE);
error_reporting(E_ALL);
ini_set('display_errors','1');
Under the <?php at the top of the wxsoil.php and see if you get a load of error to give a clue as that script is old and not 8.3 compatible
  • Mark
« Reply #2 on: February 23, 2025, 12:19:38 PM »
Try adding
Well this doesn't look good...lol  https://www.northbendweather.com/wxsoil.php
Offline hcorrin
    • Ballaugh Weather
« Reply #3 on: February 23, 2025, 12:57:17 PM »
It’s the Deprecated errors that need to be sorted the warning less so
I am not familiar with the script your using but the Deprecated errors relate to rounding or preg-match of null values other on here have had these come suggest tying a search and if Ken see this and is well enough he may steer you in the right direction
Offline swright1957
    • Hytheweather.co.uk
« Reply #4 on: February 24, 2025, 09:31:58 AM »
Hi all.
Just as a matter of interest where did the wxsoil script come from and can I have a copy please????  :grin:
"anything's possible with the weather"
  • Mark
« Reply #5 on: February 24, 2025, 05:49:38 PM »
Hi all.
Depending on what PHP version your using, It no longer works as you can see from my other post.
Offline swright1957
« Reply #6 on: February 25, 2025, 03:56:17 AM »
Hello
Im using 8.2, so would like a copy and I can see if I can get it to work with 8.2 and 8.3
  • Mark
« Reply #7 on: February 25, 2025, 07:21:11 PM »
I'll post those files once we get power and internet back. We just had a big wind storm.
  • Mark
« Reply #8 on: February 27, 2025, 09:20:32 PM »
Hello
The files are attached. Let me know if you get the script working.
  • Mark
« Reply #9 on: April 10, 2025, 11:39:13 AM »
Were you able to find a fix for this script?
Offline swright1957
« Reply #10 on: April 11, 2025, 05:46:16 AM »
Hi now sorry have now downloaded them, but ive been on my hols so no chance, will look over the weekend
Offline wvdkuil
  • Wim van der kuil
« Reply #11 on: April 11, 2025, 06:24:58 AM »
There is no "fix" needed. The script already works without problems with PHP 8.x.
The errors are caused by missing fields.
In your script the lines 44-48 read:
     <div id="main-copy">
<?php
<!-- WXSOIL START -->
I added all used fields with some values as I do not have those sensors in my test-files.
<?php
# for test
$soiltemp 10;
$soiltemp2 20;
$VPsoilmoisture 11;
$VPsoilmoisture2 21;
$yrecordhighsoil 30;
$yrecordlowsoil 0;
$VPsoiltemp2 $yrecordhighsoilmonth $yrecordlowsoilmonth $yrecordhighsoilday $yrecordlowsoilday =
$yrecordhighsoil2 $yrecordlowsoil2 $yrecordhighsoilmonth $yrecordlowsoilmonth2 $yrecordhighsoilday2
$yrecordlowsoilday2 $yrecordhighsoilmonth2 $recordhighsoil $recordlowsoil $recordhighsoilmonth =
$recordhighsoilday
$recordlowsoilmonth =  $recordhighsoilyear $recordlowsoilday $recordlowsoilyear $recordhighsoil2 =
$recordlowsoil2  $recordhighsoilmonth2 $recordlowsoilmonth2 $recordhighsoilday2  $recordlowsoilday2 =
$recordhighsoilyear2 =  $recordlowsoilyear2 =
44;
$avtempjannowsoil $avtempfebnowsoil $avtempmarnowsoil $avtempaprnowsoil $avtempmaynowsoil $avtempjunnowsoil =
$avtempjulnowsoil $avtempaugnowsoil $avtempsepnowsoil $avtempoctnowsoil $avtempnovnowsoil $avtempdecnowsoil =
55;
The script works without errors if the fields used exist. See attached screenshot.
Maybe  there is a separate file for those soil-values, or another version of testtags.php is needed.
Regards,
Wim
« Last Edit: April 11, 2025, 07:22:28 AM by wvdkuil »
Offline wvdkuil
  • Wim van der kuil
« Reply #12 on: April 11, 2025, 08:17:44 AM »
Those missing fields seems to be from the alt-dashboard scripts.
-> https://saratoga-weather.org/scripts-legacy.php#scott
--> Alt-Dashboard 6.95h Script
The download contains the Soil-leaf-Additional-testtags.txt
Add those to your testtags.txt in WD and the script should work.
Wim
« Last Edit: April 11, 2025, 08:20:29 AM by wvdkuil »
  • Mark
« Reply #13 on: April 12, 2025, 04:00:55 PM »
Thanks Wim. Got it working again.
