Author Topic: MUST READ - Fine Offset Clone Models,sensor compatibility etc -discussion thread  (Read 16355 times)
Offline Gyvate
Hi everyone,
the Fine Offset clone model overview has been updated, some more useful info added.
See the change log at the end of the thread
it's worth passing by every now and then  8-)
have a look  :-)
https://www.wxforum.net/index.php?topic=40730.0
« Last Edit: August 05, 2023, 02:57:43 AM by Gyvate »
Offline WA4OPQ
  • 4 stations: 2902 array, GW1000, 3 on Meteobridge
Re: Fine Offset Clone Model numbers etc update
« Reply #1 on: November 21, 2020, 02:25:24 AM »
This is an excellent tool. Thank you for all your work.
One quick question: Is there a reason that Ambient's clone of the WH2650 Wifi, the ObserverIP, is not listed?
Offline Gyvate
« Reply #2 on: November 21, 2020, 03:27:50 AM »
as far as I know, the Ambient ObserverIP is still the old, LAN based version which FineOffset also had in their portfolio.
That doesn't have the functionality of the of new WiFi version (Fine Offset WH2650, Froggit WH2600Pro).
This is also mentioned on the page in the respective footnote.
I guess you mean the WS-1550-IP (earlier WS-1400IP)
https://ambientweather.com/amws1500.html
I didn't see the WiFi version at their web site. The term "wireless" refers here to the transmission between sensor and console and not to the communication of the console with the local network.
In the WiFi version, the LAN outlet is closed/covered and the LEDs on the front are differently labelled (Link old, WiFi new).
« Last Edit: November 21, 2020, 03:50:07 AM by Gyvate »
Offline Gyvate
« Reply #3 on: November 21, 2020, 08:56:19 AM »
further update on table and footnotes - 21-Nov-2020
« Reply #4 on: November 21, 2020, 11:12:35 AM »
Yes, what Gyvate said 100% true. The Ambient ObserverIP is not the same as the WH2650. Ethernet vs WiFi. But most importantly the firmware is completely different. The new WiFi version uses the same firmware as the GW1000, whereas the ObserverIP version will not show live data on the WS View app. This is because the ObserverIP version (Ethernet) uses the embedded webserver pages to configure and to see the live data. It isn't just because of it being Ambient firmware, as the same is true for the Aercus version of the ObserverIP which I believe they call a WeatherLogger.
The two may look the same at first glance...but when you inspect the LED lights which are named differently and you notice no Ethernet port on the back of the WH2650 you start to realize it is a different device altogether.
« Reply #5 on: November 21, 2020, 11:16:45 AM »
Yes,
Thank you Gyvate for the great work on this new version of model/part chart.
Offline droiddk
« Reply #6 on: November 21, 2020, 11:28:16 AM »
HP3500/HP3501 can not receive multiple sensors (like WH31)?
Offline Gyvate
« Reply #7 on: November 21, 2020, 01:08:23 PM »
@droiddk
with firmware > 1.6.2 it can receive several more extra sensors, but not all.
see updated matrix.
It can receive WS68, WS80, WH40, 1-8 WH31/WH31-EP, 1-4 WH41, 1-8 WH51, 1 WH57, 1 WH32.
It cannot receive WS80, WH45, WN34, WH55.
« Last Edit: November 22, 2020, 12:08:53 PM by Gyvate »
Offline WA4OPQ
« Reply #8 on: November 21, 2020, 06:28:38 PM »
I wasn't aware of that. Thanks for the clarification.
Offline Platokidd
  • top side land of Lincoln
The AW list needs updating.
https://ambientweather.com/amwepmpmwiin.html
 Ambient Weather PM25IN PM2.5 Wireless Indoor Particulate Monitor for OBSERVERIP, WS-2000 and WS-5000
https://ambientweather.com/amwh31la.html
 Ambient Weather WH31LA Leak Detector for Models WS-2000, WS-5000 Weather Stations
https://ambientweather.com/amwh31p.html
 Ambient Weather WH31P Water Proof Probe Sensor for WS-0265, WS-1550-IP, WS-2000, WS-3000, WS-5000 and ObserverIP Series Weather Stations
« Last Edit: November 22, 2020, 08:34:22 AM by platokidd »
Ambient
ECOWITT
1-HP10 2-WH45 4-WH55 5-WH51
1-WN30 1-WH41
1-DAVIS 7714
1-STRATUS
1-Fisher Barometer 1436R-22
PWS at 2 locations.
Offline Gyvate
Thanks for the hint.
These buggers had these sensors in a different section ...   :roll:
matrix updated
Offline droiddk
 :!: HP3500/HP3501 works with WH32.
Offline Gyvate
correct - it's not explicitly mentioned but you can tell from the picture - will update the matrix accordingly
Offline Gyvate
added Weather Network support by the consoles to the table/matrix
Offline Gyvate
added a few more rebranded consoles, mainly from European resellers and updated the Weather Network info
see change log https://www.wxforum.net/index.php?topic=40730.msg419166#msg419166
Offline droiddk
One more discovery: HP3500/3501 supports up to four WH55.
Regards
Offline Gyvate
correct - since firmware 1.6.9 - in the manual it still says "pending".
But I've updated the matrix.
Offline Gyvate
also added console sizes - screen diagonal or device size where displayless
so people can have a better idea what these pieces look like in real life
This info is often missing in the manuals.
Also added information pertaining to latest firmware versions
« Last Edit: November 25, 2020, 02:59:17 PM by Gyvate »
Offline Gyvate
Re: Fine Offset Clone Model numbers and related information - discussion thread
« Reply #18 on: December 01, 2020, 03:54:55 PM »
Hi Everyone,
I know that the related thread "Fine Offset Clone Model numbers, compatibility matrix and other useful info" risks to become what we call in Germany a 'honey-sweating, egg-laying, wool-milk-pig' (in plain English probably a Swiss army knife or a jack of all trades device) ...
still having certain important information at a central place can be very helpful and can make our weather enthusiast life easier and provide orientation.
So if you feel that something is missing, some information is not correct or incomplete, feel free to post in this thread (as some of you already did before).
And there is a good chance that the missing or suggested information will find its way into the "Fine Offset Clone Model numbers, compatibility matrix and other useful info" thread.
We have chosen this approach to have the main information thread locked in order to remain clearly arranged while related discussions can be held here.  :grin: 8-).
Offline Gyvate
« Reply #19 on: December 03, 2020, 06:57:42 AM »
WiFi firmware update to V1.5.6 was updated in the firmware section.
Offline Gyvate
« Reply #20 on: December 07, 2020, 09:49:17 AM »
added Ambient WH31P (P=pool; waterproof water sensor) to the matrix.
It's part of the WH31 multi-channel family, so far only available through Ambient in the 915 MHz version.
Can be received by an Ecowitt console [see matrix, @915 MHz].
Offline Gyvate
« Reply #21 on: December 10, 2020, 06:24:09 AM »
added picture of newly released  WH45 CO2, PM2.5, PM10, Temperature/Humidity (indoor) sensor
Offline Gyvate
« Reply #22 on: December 26, 2020, 01:17:07 PM »
As there have been many related questions coming up in recent posts, I have enriched the post by an overview of the HP2551/HP2553/HP1000SEPro (Froggit) console display in a "real-life" picture. You have to scroll down, Between Matrix and change log.
https://www.wxforum.net/index.php?topic=40730.msg420959#msg420959
Merry Christmas and a Happy, Healthy and Safe 2021
« Last Edit: December 26, 2020, 05:17:03 PM by Gyvate »
Offline Platokidd
« Reply #23 on: December 30, 2020, 02:42:53 PM »
Temp/Humidity outdoor sensor - WS-2000 - Ambient WH32E is now discontinued per Ambient support.
Think the reference to WH32F was in error.
Ambient
ECOWITT
1-WN30 1-WH41
1-DAVIS 7714
1-STRATUS
PWS at 2 locations.
Offline Gyvate
« Reply #24 on: December 30, 2020, 03:54:17 PM »
Correct, the "F" should have been an "E", maybe an Early indicator of End-of-live ? :-P
will change that and add the eol remark.
Strange that they took that sensor off their portfolio - it's in no way outdated and you still get it from Ecowitt etc. (but won't work with Ambient consoles, the old proprietary story).
They only have the WH31 multi-channel available now, which is not a full replacement of a WH32, as only the WH32 will be recognized by the consoles as outdoor temperature/humidity sensor (even over all other outdoor T/H sensors like WH65, WS678 and WS80 (Ecowitt terms)).
Possibly just a marketing decision as there may have not been a sufficient number of customers interested in it. Whatever ...
And, by the way, it's not only WS-2000, it's WS-5000 too (just for completeness).
It (the WH32 T/H outdoor sensor) doesn't usually come with either of them (WS-2000 has a T/H sensor in the WH65, WS-5000 in the WS80).
Afaik it had been offered before as optional sensor, but, end of life as it seems ...
Interestingly on Ambient's web page, the sensor description for the WS-2000 is more explicit than the more modern design used for the WS-5000, even though the console is the same for both products. One more reason for the existence of our table.  ;) 8-)
