Thank you for the response. I went back through my board looking at everything measuring voltages with voltmeter. I have an oscilloscope but it doesnt work... I planned on learning how to use one but i never have had a chance to play with one that works.
ANYWAY.... I have found the problem. I never saw anywhere in the guide that said how to arrange the jumpers for the AVR pins. So i had all of the pins jumpered. I removed all of them and now the leds work. Still cannot get the gps led to illuminate. It illuminated at first until i tired to initialize the gps using the windows tracker program. After i initialized the led went off and doesnt even blink. GPS is getting information to the tracker. I can see it in the port monitor.
What i dont understand is the setup for board speed. Do i set this up for the GPS baud or for the USB interface speed? If it is for the USB interface what speed should i use?
The process i used that worked to see data streaming across the port monitor was...
sign in
assign port
select board speed.... I used 115200 at first.
select em406 gps
select gps baud 38400 (pins 1 and 2 jumpered as per instructions for 34800 baud)
initialize GPS
then it gives the error of "no port selected" Then says to reset the board.
changed board speed to 38400 and i see data across the port logger but tracker program says "no data received." and no green led. I have rechecked the wiring of the em406 module and it is correct.
Anyone know what i could have done wrong now?
](https://www.wxforum.net/Smileys/default/eusa_wall.gif)
The PPS led is flashing and the rx led on the usb-ttl board is flashing simultaneously. the led is blinking on my em406 indicating signal lock. no flashing of the tx led. i am attaching a screenshot of the portmonitor log. Its all gibberish to me. Is it supposed to look like this?
I hope i didnt screw anything up with the avr jumpers on the board. I also hope i am not being too much of a pain in the rear on this forum.
Thanks for all of your help. It is very much appreciated.
Nick
