Author Topic: New AQM Sensor coming (CO2-PM2.5-PM10)  (Read 1369 times)
Offline Mandrake
« on: May 15, 2020, 07:06:10 AM »
Exciting confirmation from Ecowitt that there is a new combined AQM sensor being developed for sale.
It will be a CO2, PM2.5 and the much asked for PM10 as well
It will also include temperature and humidity
Early days but this sound a good development for those interested in Air Quality
G1ZFO
Ecowitt GW2000 (Test)
Ecowitt WS90 Wittboy - Test
Ecowitt WH41 PM2.5 AQM Sensor
Ecowitt WN35 Leaf Moisture
Offline K7RMK
    • East Wilson Weather
Re: New AQM Sensor coming (CO2-PM2.5-PM10)
« Reply #1 on: May 15, 2020, 10:42:49 AM »
Will this fix the humidity problem?
Ecowitt GW2000 + Meteobridge on RPI 4B
Ecowitt HP2551-C Display Console
Ecowitt WH32-EP Outdoor Temp/Humidity Sensor + MeteoShield Pro Radiation Shield
Ecowitt WS68 Anemometer
Ecowitt WH40 Rain Gauge
Ecowitt WH41 Outdoor PM2.5 Air Quality Sensor
Ecowitt WH43 Indoor PM2.5 Air Quality Sensor
Ecowitt WH31 x4 Temp/Humidity Sensors
Ecowitt WH51 Soil Moisture Sensor
Ecowitt WH34S Soil Temperature Sensor
Ecowitt WN35 x2 Leaf Wetness Sensors
Offline Mandrake
« Reply #2 on: May 15, 2020, 02:19:08 PM »
I think that's probably unlikely as the device would need to incorporate a heater to dry the sampled air as the professional systems do.
Though its possible I suppose that the sensor will be able to compensate somehow when it detects high humidity so its possible that there might be some improvement for high humidity events like mist/fog/heavy rain that impacts PM detection.
I guess we will need to wait and see, but quite exciting none the less!
G1ZFO
Offline K7RMK
« Reply #3 on: May 15, 2020, 03:20:02 PM »
Do the PurpleAir air quality sensors have a heater in them? I know they use the Plantower PMS5003 sensor which shows a working humidity range of 0-99% on the datasheet.
Offline wvdkuil
  • Wim van der kuil
« Reply #4 on: May 15, 2020, 03:47:08 PM »
The Plantower sensor will work width humidity range 0-99%. That does not mean the measurements are as correct as a heated professional station.
None of the consumer versions will work that good  in high humidity conditions. They all over-estimate the PM.
I own 2  Luftdaten, 1 PurlpleAir and 2 Ecowitt sensors.
All have the same "problem" with high humidity, and they follow roughly the same graph-path when humidity increases.
Offline Steve F
« Reply #5 on: May 20, 2020, 02:09:45 AM »
Really keen on this one, the one thing I miss from my Netatmo indoor station is the CO2 readings.
Offline Mapantz
    • Wareham Weather
« Reply #6 on: May 20, 2020, 08:16:49 PM »
I was going to reply with the exact same thing! The Co2 readings were awesome.
I really hope that an app can be developed that can allow notifications for weather events/high Co2 etc..
I can't speak for everybody, but i'm pretty sure that a lot of people crave to get notified that it has just started raining, or a wind gust exceeded 50mph. Such a high percentage of people carry a device of some sort and they reply on being notified for everything.
« Reply #7 on: May 20, 2020, 08:32:21 PM »
Ecowitt.net already has these notification email alerts. Perhaps not as defined as we would like, but that is only a matter of minor development as the infrastructure is already there to do all this.
Offline Mandrake
« Reply #8 on: May 21, 2020, 08:44:06 AM »
Indeed, you can certainly set an alert for wind speed breaching a certain value on Ecowitt.net to send you an e-mail
Likewise for PM2.5 values, so I am sure when the new sensor is released that alerts will be available against these values!
G1ZFO
Offline Mapantz
    • Wareham Weather
« Reply #9 on: May 22, 2020, 08:59:14 PM »
Getting emails is a waste of time. I don't use email on a mobile device, only on a laptop or PC. It's a redundant feature for me.
Push notifications need to be implemented somehow. It's the best way forward.
