Author Topic: Blank web site  (Read 678 times)
Online Otis
  • (aka Paul)
    • Lake Huron Weather
Blank web site
« on: August 16, 2022, 06:19:33 AM »
I’m not sure what happened but all of a sudden, my web site is not viewing, just a blank page(s).
lakehuronweather.org
The only mod I made was to install the GEOS18 script, which I have since deleted.
Otherwise nothing had changed.
Any assistance would be appreciated.
Note: my data appears to be uploading to my site okay.
Thanks for any help.
CW3699
Offline broadstairs
Re: Blank web site
« Reply #1 on: August 16, 2022, 06:57:21 AM »
Not much to go on, looking at what is sent it stops with a blank line after the html statement on line 3. If removing that script did not fix it then there is something else changed which you've not noticed but without seeing the raw code it's not possible to tell. Your server should I think be showing some error(s) which would help but we cannot see anything here.
Stuart
Online Otis
  • (aka Paul)
Re: Blank web site
« Reply #2 on: August 16, 2022, 09:04:41 AM »
What code would be helpful to see?
CW3699
Offline wvdkuil
  • Wim van der kuil
Re: Blank web site
« Reply #3 on: August 16, 2022, 09:40:09 AM »
Please add the unzipped _test.php to your website folder.
https://lakehuronweather.org/_test.php
If there are any PHP errors causing this, those will be displayed then.
Offline wvdkuil
  • Wim van der kuil
Re: Blank web site
« Reply #4 on: August 16, 2022, 09:46:37 AM »
Running your https://lakehuronweather.org/check-fetch-times.php?show=wx  shows invalid testtags.php
It suddenly ends in line 815 causing a PHP fatal error 500
$yrecorddayswithrainday = '8';
$yrecorddaysnorainmonth = '1';
$y
Check the testtags.txt file in your WD folder on your PC.
Succes, Wim
Online Otis
  • (aka Paul)
Re: SOLVED - Blank web site
« Reply #5 on: August 16, 2022, 10:05:18 AM »
Wim, thank you so much for the input.
I deleted the testtags file from my site and restarted WD, seems to be working now.
Another example of the helpful nature of the members here.
Thanks  [tup]
CW3699
