How strange to hit BO live maps and see zero for Region 3... North America
Since no flashes, this would be excellent time to check your stations for noise, and excessive gain, for example.
Good time to go all manual and adjust for and troubleshoot those bothersome intermittent, or constant signals...
Go to participants page, you don't even need to log in... and see the Signals column.
You might think that best 'locally' optimized stations would have lowest signal counts... that may not necessarily be true
under normal 'storm cell' activity... and this doesn't mean you have a 'bad' station.... but if you've got a high number of counts, this may be a good time try and track down some causes and effects.... enjoy!
The other things you'll note, is that cranking up LMOrg stoke display, you'll still see some false positives, and some are in weird locations....
Mike
