Author Topic: "Low battery on station 1" message on console  (Read 1335 times)
Offline Andy Thompson
  • Southern Minnesota Live Weather
  • Madelia and Thompson Farms
« on: August 01, 2021, 09:10:00 AM »
I'm not sure if this topic has been brought up before. The low battery message is always being displayed on the console at the bottom. I put a fresh Energizer rechargeable battery in the ISS and also cycled power to the console to see if that would get rid of it. Anyone ran into this issue before?
Regards,
Andy Thompson
www.somnwx.com
Re: "Low battery on station 1" message on console
« Reply #1 on: August 01, 2021, 10:15:01 AM »
Offline cmelby76
« Reply #2 on: August 01, 2021, 01:30:39 PM »
I wouldn’t use a rechargeable battery..  Use a lithium battery.
Offline azchrisf
« Reply #3 on: August 02, 2021, 03:25:01 PM »
*Check the voltage of the battery. It must be at least 3V. IIRC the console will start throwing warnings at ~2.8V and below.
You may also have a bad supercap which is draining the battery immediately. Pull the new one out - if it is still at 3V or close to it, it could be a circuit board issue. Check the battery contacts for corrosion, etc. and that they are making good contact. If all else fails, contact Davis.
The link posted by @johnd is a great article.
Also doing Soil and Leaf 4x
My setup:
Offline Aardvark
    • turned off
« Reply #4 on: August 02, 2021, 05:00:28 PM »
I had that happen a few times,  I went out and put in a fresh battery , then again, and again.  finally I ordered a new ISS board and no problems since.  They do go bad.  Check to see if the station is still under warranty and ask for a new replacement, that you will send them the present upon reciept.  Don't use rechargeable batteries.  They don't recharge in the ISS.  When they discharge, you get the message.   Put in a standard cr123A  .
