Author Topic: Ambient Weather Station Beta Testers needed :)  (Read 9711 times)
Offline jmello65
Re: Ambient Weather Station Beta Testers needed :)
« Reply #150 on: July 29, 2021, 05:07:50 PM »
Hello. Anyone hooking up Weatherflow or Tempest.  Am having problems with wind. I have a weatherflow and tempest. Seems to be using stats from both stations. Help
Offline jmello65
« Reply #151 on: July 29, 2021, 05:12:05 PM »
Anyone hook up an ecowitt to weatherwizz. Is the info / whats needed to hook up weatherwizz all entered on the ecowitt console screen.
How about vantage pro or weatherlink
Asking because i dont think wind is working correctly. Help. Detailed info. Thanks
Offline SnowSentry
    • WeatherWizz
« Reply #152 on: July 30, 2021, 05:01:54 AM »
Hi jmello65,
I don't own an ecowitt station so when I was making my instruction on how to set it up I took all my information given to me from the good people here who helped me out.
I am sure someone will correct me if I am wrong.  But as I understand it, you should have an ecowitt mobile app that you use to enter the settings.
Do you have the ecowitt mobile app?
Offline Gyvate
« Reply #153 on: July 30, 2021, 05:46:56 AM »
Hi @jmello65
please open a new thread giving it a subject which summarizes your issue in the proper board
weatherflow tempest is NOT a FineOffset (clone) weather station - you have to post in the "other weather station hardware" board
https://www.wxforum.net/index.php?board=70.0
Offline SnowSentry
    • WeatherWizz
« Reply #154 on: July 30, 2021, 08:16:54 PM »
can you try again, I found a bug where the wind chill should have switched to heat index but didn't
I am not seeing any data in Apparent Temperature when set to "Feels Like".  If I change to Wind Chill/Heat Index, I get a wind chill temperature but that really isn't of value in the summer.
Offline funsutton
    • Weather Underground
« Reply #155 on: August 01, 2021, 10:18:34 AM »
Hi SnowSentry.
I finally had  a thunderstorm overnight since I started using weatherwizz and according to my ambient console, i had 53 lightning strikes with the last one a distance of 9 miles.
However on sew0001 this is what it shows:
It does show the time and date of the last one, but no counts or distances. Just fyi.
Offline olicat
    • FOSHKplugin
« Reply #156 on: August 01, 2021, 11:20:59 AM »
Hi!
This is because the corresponding keys are different:
Ecowitt              Ambient
lightning_num   lightning_day
lightning           lightning_distance
Should be easily fixed on server side.
Oliver
Offline SnowSentry
    • WeatherWizz
« Reply #157 on: August 01, 2021, 05:31:55 PM »
All fixed, Lucky you getting a thunder storm.  Not had a good thunder storm in a long time.
That Oliver for the quick info :)
Hi SnowSentry.
Offline olicat
    • FOSHKplugin
« Reply #158 on: August 01, 2021, 06:03:27 PM »
Hi!
May I express another wish?
It would be very helpful if we could change the names of the sensors - for example instead of H1 "Kitchen" or instead of Soil Moisture 3 "Lawn".
This would increase the clarity - especially with a large number of sensors.
In the dashboard there could be another point "Name your Sensors", in which you can make a simple assignment:
H1: sensor name
T1: sensor name
SM1: sensor name
I realize that there will be problems with the length of the names. But you could cut off names that are too long so that the layout is not destroyed.
That would be helpful - probably for other users as well.
Oliver
Offline SnowSentry
    • WeatherWizz
« Reply #159 on: August 01, 2021, 06:45:50 PM »
Hi Olicat,
Thanks for that.  I will add this to my growing wish list :)
Hi!
H1: sensor name
T1: sensor name
SM1: sensor name
Oliver
Offline funsutton
« Reply #160 on: August 01, 2021, 07:20:37 PM »
Looks great! Thanks for fixing it so quickly.
Offline olicat
    • FOSHKplugin
« Reply #161 on: August 02, 2021, 07:30:52 AM »
Hi!
This way you could also make all field names changeable and would have fulfilled the wish for different language versions:
Outdoor Temp Außentemperatur
HUMIDITY Luftfeuchte
AIR PRESSURE Luftdruck
Two birds with one stone (Zwei Fliegen mit einer Klappe) ...
Oliver
Offline SnowSentry
    • WeatherWizz
« Reply #162 on: August 02, 2021, 07:45:54 AM »
You make a good point :)
Hi!
Oliver
Offline davidefa
« Reply #163 on: August 02, 2021, 09:31:07 AM »
Due piccioni con una fava...
Offline Gyvate
« Reply #164 on: August 02, 2021, 09:51:49 AM »
Looks like the Germans are the most humble in terms of the size of the animals used in this metaphor.  8-)
The French also use a stone but keep the object they are hitting open.
Faire d'une pierre deux coups
Offline kheller2
« Reply #165 on: August 02, 2021, 10:31:30 AM »
Perhaps I missed it in this thread, but I noticed on my dashboard (with ambient API key) that the Temp min/max aren't updated (just dashes), and that some of the gauges are blank at times  -- I'm assuming this is because the value hasn't changed or something.  Example: My wind-chill is almost always dashes and the UV sometimes is.
Ambient Consoles: WS-2000, WS-1900, WS-1200, WS-2902C, WS-3000-X3, WS-0900-IP(observerIP), WS-1001-WIFI
Ambient Arrays: WH65B
Ambient Sensors: WH31E(3), WH31B(2), WH32B, WH31SM(2), WH31PGW, AQIN, WH31LA(3)
Ambient Spares: WH24B(2), WH25B.
Ecowitt: HP2551BU, GW1000B(dead), GW1100B(2), GW2000B
Ecowitt Sensors: WH51, WN34BL, WN34(2), WH31, WH41, WH40
Offline SnowSentry
    • WeatherWizz
« Reply #166 on: August 02, 2021, 05:02:47 PM »
Hi kheller2,
The Ambient API does not support Temp Min/Max nor does it support Wind-Chill/Heat index.  It does appear to support the UK "Feels Like" so perhaps switch your settings for Apparent temperature to "Feels Like".  As for UV I can see the the value updating on your dashboard not sure what you are seeing.
Hope this helps :)
Offline Platokidd
  • top side land of Lincoln
« Reply #167 on: August 02, 2021, 06:39:27 PM »
Same here with aw. Switch to the GW1100 and same thing.
Ambient
ECOWITT
1-HP10 2-WH45 4-WH55 5-WH51
1-WN30 1-WH41
1-DAVIS 7714
1-STRATUS
1-Fisher Barometer 1436R-22
PWS at 2 locations.
Offline olicat
    • FOSHKplugin
« Reply #168 on: August 07, 2021, 08:35:30 AM »
Hi!
As I see my wish
was fullfilled.
You will find this new feature on your account-page under "Choose your options" and "Sensor names".
But - as far as I can see - only for paying members (patreons) for 3,50EUR plus tax per month.
Is this an annual contract or can one book this service - as required - monthly ?
Regards, Oliver
Offline SnowSentry
    • WeatherWizz
« Reply #169 on: August 07, 2021, 09:09:11 AM »
Hi Olicat,
There is no contract using Patreon.  You can cancel any time.  All features will be enabled while you are a member and disabled when/if you cancel membership.
Offline SnowSentry
    • WeatherWizz
« Reply #170 on: August 08, 2021, 01:57:38 AM »
Hi All,
I have just released the first WeatherWizz website integration.  This allow you to embed your live weather data into your own site.
Login to your account and get your unique script to put into your HTML page and WeatherWizz will render an animated real time banner at the bottom of your page for your visitors to see your live data.
Sample
I hope you find this useful.  If you do, please post the your we page links so we can all check it out! :)
Offline Gyvate
« Reply #171 on: August 08, 2021, 01:09:34 PM »
Nice ! - Could there be also Solar Radiation and UV visible ? That's what people want to know when they go somewhere  ;)
In addition, otherwise the nice banner looks half-empty
Offline Rover1822
« Reply #172 on: August 08, 2021, 01:21:24 PM »
And nearest gas station
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
  WittBoy WS90 + GW2000
  WS90 (other one) + GW1100
Personal Sites: Weather Cam
Offline Gyvate
« Reply #173 on: August 08, 2021, 01:33:03 PM »
that's too difficult - there could be two just opposite to each other ... :-P
Offline funsutton
« Reply #174 on: August 12, 2021, 05:36:12 PM »
What does the 14 mean under the lightning bolt?
