Author Topic: Weather Underground upload stopped  (Read 435 times)
Offline springhead
    • Tunbridge Wells Weather
« on: April 22, 2021, 12:27:07 PM »
Was running fine from my GW1000 the stopped in the middle of the night last week.  WS View has the correct station ID and Key but Weather Underground says my station is offline.
It's not a new account, I've had it for about 4 years.  Any ideas?
Offline Rover1822
Re: Weather Underground upload stopped
« Reply #1 on: April 22, 2021, 12:50:35 PM »
Are you sending to any other online sites like Ecowitt.net and are they working ?
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
  WittBoy WS90 + GW2000
  WS90 (other one) + GW1100
Personal Sites: Weather Cam
Offline springhead
« Reply #2 on: April 22, 2021, 01:07:41 PM »
Yes it’s fine on Ecowitt and Weewx.
Offline Gyvate
« Reply #3 on: April 22, 2021, 01:52:22 PM »
On April 20th, midnight (CEST) through 21:00, two of my stations (WH2320E [ISAARB3] and HP2551 [ISAARB22]) posting to WU show a gap.
On other stations around me I noticed a gap between 18:00 and 21:00 the same day [ISAARB8, ISAARB23], and one with a gap from 02:00 - 21:00 [ISAARBRC162].
Looks as if there was / is an issue with WU.
« Last Edit: April 22, 2021, 01:54:40 PM by Gyvate »
MeteobridgePro(2)[test,prod] 5.8 Mar 01 2024, 15185 - Blake-Larsen Sun Recorder - RPi4/weewx 4.8.0/4.10.2/CumulusMX 3283/Meteobridge RPi4B-2GB,
Barani Meteoshield Pro, MetSpec Rad02
weather landing page: http://meshka.eu
WIKI http://meshka.eu/Ecowitt/dokuwiki
Offline springhead
« Reply #4 on: April 22, 2021, 02:09:22 PM »
I think that’s a different issue to me.  Mine stopped in the middle of the night on 16th April and has been completely dead since.
Offline Gyvate
« Reply #5 on: April 22, 2021, 02:19:43 PM »
what about a restart (power-cycle - disconnect USB - wait 10 seconds - re-connect), a reset (press black reset bar between LEDs for < 10 seconds) or/and a factory reset of the GW1000
(press the reset bar > 10 seconds or insert a staple end into the hole between the top slits on the reverse side for > 10 seconds - will need to repeat the pairing process between GW1000 and WiFi router)?
(Save calibrations, rain totals and API keys before factory reset !!)   8-)
Does it make a change ?
« Last Edit: April 22, 2021, 02:23:46 PM by Gyvate »
Offline Rover1822
« Reply #6 on: April 22, 2021, 02:23:27 PM »
Although this sounds weird, also try restarting your router, I'd do that before doing a factory reset on the GW1000.
I would do the power cycle on the GW1000 first, as Gyvate described. Wait 10 minutes or so. If nothing on WU, then try the router restart, then wait 10 minutes for WU. If nothing then proceed with the GW1000 resets as Gyvate  described.
« Last Edit: April 22, 2021, 02:29:22 PM by Rover1822 »
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
Offline springhead
« Reply #7 on: April 22, 2021, 02:42:39 PM »
I tried a GW1000 power cycle a few days ago with no joy. I could easily do a router reboot. Other thing I can try is wunderground upload from weewx, might show if it’s here or wunderground account issue.
Offline springhead
« Reply #8 on: April 22, 2021, 04:05:46 PM »
I enabled Weather underground logging from within Weewx and that's working, so my account and details are fine.  Disabled it again in weewx and still nothing being upload by the GW1000.  I deleted the station ID and key from WS View, saved it, then went back in entered it and saved.  Still not uploading.  Router reboot makes no difference either.
So I have a work around via Weewx but something not happy with the GW1000.
« Last Edit: April 22, 2021, 04:13:51 PM by springhead »
