Author Topic: Barani MS Pro vs SmartCellino radiation shield comparison  (Read 159438 times)
Offline Jasper3012
Re: Barani MS Pro vs SmartCellino radiation shield comparison
« Reply #700 on: February 26, 2025, 12:42:15 PM »
For those curious, this is how high the sensors are placed in both shields. About 10 cm above the bottom plate.
Hi, can I ask you what sensors they are? DS?
They are NTC thermistors.
Offline ivano
    • http://www.supermeteo.com/stazione/ortelle/
« Reply #701 on: February 26, 2025, 02:33:06 PM »
ah ok, and how do you acquire the data? Sorry for my questions but I'm intrigued
1)3 gw1000 +1 GW2000+GW3000
2)hp2551
3)ws90
4)ws68
5)2 wh32 EP
6)5 wh31 EP
7)2 meteoschield pro 3° gen
8)1 New Fars meteoshield pro 3° gen
9) davis 7714 Black
10) 2-wh40
11)schermo solare RAD-14 Metspec
12)schermo solare RAD-02 Metspec
13)Meteorain 200 compact (Barani)
14) Davis vp2 pro ventilata
15) GW1001 ecowitt
16)schermo solare  Comet system da Cometeo
17)Apoge TS-100
18)Meteoshield pro 2 gen
template http://ortellemeteo.altervista.org/pwsd/
webcam :https://rtsp.me/embed/tRhazi3z/
Offline Jasper3012
« Reply #702 on: February 26, 2025, 02:50:05 PM »
Via the Sigfox network.
Offline mauro63
« Reply #703 on: February 27, 2025, 09:48:55 AM »
Yesterday's report
M.
Offline mauro63
« Reply #704 on: March 01, 2025, 11:48:42 AM »
Yesterday's report
M.
Offline Jasper3012
« Reply #705 on: March 02, 2025, 05:24:21 AM »
This morning, with high pressure giving calm, sunny and frosty weather, I got another opportunity to potentially record the low sun/low wind effect we've been talking about. While nothing interesting was happening during the first 2 hours after sunrise, possibly due to ice on the shields, at 10 AM, the MS did suddenly go 0.3C and then 0.4C higher than the SC for some time. This happened after about 20 min of very low wind (~1 km/h or so at shield height) and with full sunshine, at an angle of about 20°. The ice on the shields had long melted by this point, so the sudden difference in temp between the shields can't be attributed to this. I suspect this was in fact the MS Pro suffering from the low sun/low wind effect, albeit only to a modest degree vs the SC. This is possibly another piece of evidence suggesting that the SC does suffer a bit less from this effect, likely to a more enclosed sensor chamber. Here's the link to the data, so you can see for yourself: https://meteo-be.net/en/charts/male-brugge/last_24h
Offline Jasper3012
« Reply #706 on: March 03, 2025, 07:09:43 AM »
Another morning with light wind and sunshine. The temperature evolution was quite interesting, with the Barani going 0.1-0.2C cooler when the dense mist rolled in overnight and then going 0.2-0.4C warmer than the SC when relative humidity dipped below 100% (timing based on nearby stations). To me, this indicates a slight overcooling on the Barani during saturation, later offset due to the onset of the low wind/sun effect.
« Last Edit: March 03, 2025, 07:14:21 AM by Jasper3012 »
Offline mauro63
« Reply #707 on: March 04, 2025, 02:40:12 AM »
Yesterday's report
M.
Offline ivano
« Reply #708 on: March 04, 2025, 04:10:28 AM »
Good morning everyone, I too add myself to this discussion, I have the Siap version with central shaft, I will post my daily report of my comparisons with different types of screens, both ventilated and passive,
this is yesterday's report 03-03-2025
2)hp2551
3)ws90
4)ws68
5)2 wh32 EP
6)5 wh31 EP
9) davis 7714 Black
10) 2-wh40
15) GW1001 ecowitt
17)Apoge TS-100
Offline Jasper3012
« Reply #709 on: March 04, 2025, 01:45:10 PM »
Welcome to the club! Maybe it's a good idea to remove some shields from your reports and only keep the "main" ones like the Siap, Barani, Davis and Apogee? Right now, your report is a bit overwhelming.
Offline Jasper3012
« Reply #710 on: March 04, 2025, 01:50:04 PM »
Another interesting day with sun and light wind. There seems to be a trend for the low wind/low sun effect not to occur when RH is at 100%, as I've not observed any difference in the past few days in the first few hrs after sunrise with full saturation. When the RH drops below 100% and there is sun and light wind, then I have been seeing a slight overheating of up to 0.4C on the Barani, relative to the SC.
 [ You are not allowed to view attachments ]  [ You are not allowed to view attachments ]  [ You are not allowed to view attachments ]
Offline Jasper3012
« Reply #711 on: March 04, 2025, 01:57:11 PM »
Temperature/humidity measurement from another one of my stations, 3.5 km away from the test location, also in a SmartCellino shield. You can see that the dewpoint was around 4C and if we assume the dewpoint to be similar at the test location, we can establish that the RH dropped below 100% at ~10:30 AM. Interestingly enough, that's nearly the exact time when there started to be more significant differences between the shields, indicating a likely relationship between RH and the low sun/low wind effect.
Offline ivano
« Reply #712 on: March 04, 2025, 02:17:53 PM »
jasper in your opinion the barani fars and the metspec rad-14 are secondary screens? the report is that if you scroll you will find the various comparisons between all the screens, if I had room in the workstation I would still add Comet type screens another pro a modified davis 7714, but unfortunately I have to settle for these  :grin:
2)hp2551
3)ws90
4)ws68
5)2 wh32 EP
6)5 wh31 EP
9) davis 7714 Black
10) 2-wh40
15) GW1001 ecowitt
17)Apoge TS-100
Offline Jasper3012
« Reply #713 on: March 05, 2025, 02:05:20 AM »
“Secondary” is the wrong word but this thread has mainly been about the SC vs MS Pro, with the Davis mixed in there aswell. I just think your report would be less overwhelming if you excluded one or two more shields.
Offline Kallo78
« Reply #714 on: March 06, 2025, 01:57:22 AM »
My report of yesterday with interesting behaviors in the morning because of the strong humidity and the different reactivity of the sensors
Offline Jasper3012
« Reply #715 on: March 09, 2025, 06:07:16 PM »
Another interesting morning with sun and weak winds. This time, the low sun/wind effect occurred much sooner after sunrise than previous times and when I checked the humidity values, the RH likely never reached 100% at shield height, meaning that the effect could occur almost immediately as the sun started shining on the shields. At this point, I think it’s obvious that there’s some sort of link between humidity and the severity of the effect on both shields. The Barani definitely seems to suffer a lot more than the SC with RH <100%. I’ve also noticed the wind doesn’t have to be dead calm for a difference to occur, just like today, where it occurred with gusts over 2 m/s at 5 m height.
Offline mauro63
« Reply #716 on: March 11, 2025, 08:58:32 AM »
Yesterday's report, without password because it's rather educational  ;)
M.
Offline mauro63
« Reply #717 on: March 12, 2025, 05:11:09 AM »
Some screenshots from yesterday, to note, in the frequent temperature changes the different reaction speed of the DS sensors compared to the Sensirion multiparameters
 [ You are not allowed to view attachments ]  [ You are not allowed to view attachments ]  [ You are not allowed to view attachments ]  [ You are not allowed to view attachments ]  [ You are not allowed to view attachments ]  [ You are not allowed to view attachments ]
M.
« Last Edit: March 12, 2025, 05:13:22 AM by mauro63 »
Offline mauro63
« Reply #718 on: March 15, 2025, 10:55:13 AM »
We have revised the structure of the comparison reports, maintaining the main features and the one-minute sampling
A special thanks to Marco, alias Kallo78, for his efforts to standardize the reports, thus facilitating their viewing and related analysis.
As an example, I attach my report from yesterday
M.
Offline mauro63
« Reply #719 on: March 16, 2025, 05:19:06 AM »
Yesterday's report
M.
Offline Jasper3012
« Reply #720 on: March 16, 2025, 05:27:52 AM »
Comparison over the last ~30 days. Very little differences, besides shortlasting low wind/low sun effects on the Barani.
« Last Edit: March 16, 2025, 05:32:20 AM by Jasper3012 »
Offline Kallo78
« Reply #721 on: March 17, 2025, 10:12:45 AM »
Unfortunately I can not attach my reports despite the size is around 2.5mb
Offline mauro63
« Reply #722 on: March 19, 2025, 04:36:15 AM »
Yesterday's report
M.
Offline Jasper3012
« Reply #723 on: March 19, 2025, 07:22:28 AM »
Bit of a breakthrough this morning! With light winds, sunshine and RH <100%, the MS Pro shot up to 0.9C warmer than the SC at one point. I suspect the SC itself was also suffering from the same effect but obviously to a much lesser extent than the Barani. Biggest difference I’ve recorded between the two shields so far.
Link to the data, so you can see for yourself: https://meteo-be.net/nl/grafieken/male-brugge/last_24h
Offline mauro63
« Reply #724 on: March 25, 2025, 05:06:54 PM »
Hello everyone,
too many problems posting reports, it is not possible to attach pdfs of dimensions that do not exceed the maximum dimensions accepted by the forum
Sorry, those who want to request the reports, ask privately
M.
