Should we use a local airport as a barometer calibration tool?
The manuals of our weather stations and some weather-related books suggest using a close-by airport to do the initial set up and calibration of your barometer.
Perhaps their reasoning is to calibrate our barometers with a convenient and free calibration tool.
However, using an airport as a reference calibration tool is not ideal. According to David Burch's, The Barometer Manual, a minimum of four or five airports should be used for calibration purposes. For calibration purposes, one airport is not enough, he says. Stephen Burt of the Weather Observer's Manual echoes that viewpoint, but adds another rather strict provision: your weather station should be surrounded by close multiple METARS (synoptic stations) i.e. NSEW of your location.
Unlike our personal weather stations, keep in mind that airport weather stations (AWOS or ASOS) calculate their station pressures. Absolute pressure is not published and is unknown. Sensor elevation is not published and unknown. For personal weather stations, absolute pressure (station pressure) is a measured (actual value). Sensor elevation is known (Dr. Burch likes to use Google Earth to determine elevation).
Rather than using several airports to calibrate your barometer, the best way to calibrate is by using another reference barometer. All you need to is to adjust your absolute pressure to match the same reading (side-by-side) with a reference sensor of known accuracy. Known accuracy is key.
Can you use a smartphone as a calibration tool? Phones, even top-of-the line ones, have no assurance of being calibrated by the phone manufacturer. Therefore, using barometer phone apps will be as good as their phones reported absolute pressure. They might be,accurate or they might not be accurate. We don't know unless we check. Phones calculate elevation poorly so depending on how the app works, it is better to determine your elevation manually from another source like Google Earth.
Almost all barometers drift over time (sometimes quite quickly) and accuracy suffers. Few of us can afford to send our barometers to a calibration lab for yearly barometer calibration, as annual costs start around $200 USD (and up) for this service. However, we can obtain a low cost, accurate barometer that has been checked for accuracy in a calibration lab. This unit can be used as our calibrated reference barometer.
Note: I am referring to the Starpath UB baro.
Using a calibrated reference barometer side-by-side with your barometer is the only way to be sure that your barometer's readings (or phone readings) are accurate. If you know your absolute pressure has been calibrated properly, then you can calculate (or have your console) calculate an accurate sea level pressure like Altimeter setting.
