We've had a boring last 24 hours, weather wise. Forecast has been partially cloudy for last night and this morning. Nothing to write home about, very scattered, and very high altitude.
I've been playing/testing GRLevel3 for my area. I've noticed base reflectivity 1 shows a ton of light blue and green cells around my area. I don't remember seeing so much activity on GR3 maps on others websites.
I've read a bunch on what base reflectivity is, what the different numbers mean, etc.. I try not to ask questions unless I've searched for the information in google, forums, FAQs, etc.. From what I have read, base reflectivity is used to show water/ice in the air. This is the main method of seeing precipitation on radar. The levels are the angle of the radar signal. 1 being closest to the ground and 5 being much higher.
If I compare BR1 maps to what I see outside, areas with 5-10 DBZ typically have light smooth clouds over them. These clouds do not look like they are producing rain, and no rain is reported on any other map I've looked at. I'm starting to question the information from NWS. Maybe GRLevel3 is too sensitive, or maybe I just don't get it.
As always, I've uploaded data to our website to share. I think it would be silly to ask others opinion on how to interpret our data without showing you the maps.
The directory where the images are currently is
www.castlerockweather.org/images/GR3. I don't allow directory browsing, so you will have to include the image names. They are the standard G3Level3 names. I.E br1.jpg, br2.jpg, br3.jpg, etc..
Here is a full link to BR1:
www.castlerockweather.org/images/GR3/br1.jpgI'll leave it up to you to change the image name to see the other images.
Thanks for your help/opinion in advance.
