Hi, This is my W. Methuen MA V PRO+ setup installed in July 2019. I use the Meteobridge NANO-SD as the Internet interface via WiFi and Weather34's Stand Alone Console V7.34 as the Local Console on a dedicated 6th iPad. I found the Vantage Pro2's Console Display unusable so I've been using Weather34's Full Template since Aug 2019 and switched to Weather34's Stand Alone Console its usability speaks for itself.
The Rain Gauge will be updated to the single spoon version which is on order.
The Solar Panels at the base supply power for V Pro's Console with NANO-SD and the Console iPad 24/7 with enough reserve to charge 2 LIPO Packs used for charging our other iPads and iPhones
Added a CoCoRaHS type Stratus Manual Rain Gauge it can be seen in the photos atop the fencing. It's Cone opening is 6'6" above ground plus approx 30ft from the closest corner of the house. It will be interesting to see how its readings compares to the Davis ISS's Rain Gauge.
Forgot to add where I'm sending my data
