Author Topic: new firmware version for WN1980: V1.3.7  (Read 253 times)
Offline olicat
  • GWxx00, HPx5x1C, WN19xxC & WS3xx0C
    • FOSHKplugin
« on: April 25, 2025, 04:11:01 AM »
Hi!
There's a new firmware version V1.3.7 available for the WN1980.
Use the current WSView Plus app or the web interface (WebUI) of the WN1980 ("Device Setting") to update.
Changelog for V1.3.7:
  • Optimizes Socket secure closure
  • Supports IoT device WFC02
No problems so far..
Oliver
Offline Dirk27
Re: new firmware version for WN1980: V1.3.7
« Reply #1 on: April 25, 2025, 06:55:42 AM »
... also for the WN1820/1821.
Dirk
Ecowitt GW1100, GW1200, 2x GW2000, GW3000, WH57, 4x WN31, WN34D, WH0291_C, WH51, WH0290_C, WH41, HP10, LDS01, AC1100, WFC01, WN1980_C, WN1821_C
Froggit HP1000SE PRO, T&HP [WN32P], DP1100, DP80, WH2626, DP40, DP30, DP250, DP10, DP70
DNT DNT000005 [WH32F]
[Out of order: Galileo's Thermometer, Crystal Ball, Fitzroy's Storm Glass]
Beginners' WiKi: https://meshka.eu/Ecowitt/dokuwiki/doku.php?id=beginners
Offline Dirk27
« Reply #2 on: April 25, 2025, 10:51:37 AM »
... looks like the WN1821 is now also able to show the outdoor temperature of a WH32 outdoor in the WN31 display area.
Dirk
Offline Gyvate
« Reply #3 on: April 25, 2025, 01:24:02 PM »
to be a bit nit-picky, it is not a WN31 display area but a temperature/humidity display area  ;),
and since meanwhile a long time, since firmware 1.2.3 to be precise, a WN32/WH32 outdoor T/RH sensor can also be displayed there
see firmware changelogs in the WiKi  8-)
WS2350 1.7.0,GW1000 1.7.7,WH2650 WiFi 1.7.7,GW1100 2.3.7,GW1200 1.3.4,GW2000 3.2.1,GW3000 1.0.3,HP2550 2.0.1,5.1.9; HP3500 1.7.2,WS3800 1.3.4, WS3910 1.3.4, WN1910 1.2.4,WN1820/WN1980 1.3.5;
Ecowitt WS90, WS85, WS80, WS68, WS69, WN30, WH31,WH31-EP, WH32,WH32-EP, WH32B/WN32P, WN34D,L,S,  WN35,WH40, WH41[PM2.5], WH45, WH46D, WH51, WH55, WH57, LDS01
Blake-Larsen Sun Recorder - RPi4/weewx 4.10.2/CumulusMX 4063/MeteobridgePro 6.1,Meteobridge RPi4B-2GB,MB VM
Barani Meteoshield Pro,MetSpecRad02,SMarTCELLino;Dracal BAR20
WIKI https://meshka.eu/Ecowitt/dokuwiki
