Author Topic: Possible mods to reduce sun-related temperature increase for WS 5000 array  (Read 2891 times)
Offline jcjrogers
Thanks guys! One more question: the Ambient website doesn't show its own WH31E as compatible with the SRS100LX, which appears to have the same dimensions as the WH32. I realize Ambient puts as little effort as possible into support and even into updating their website, but will the WH32 fit without any modifications?
the WH31E and a WH32 have the same housing size.
Ambient states for the SRS100LX
"Some sensors require the removal of mounting bracket or aesthetic covers to fit within the inner cavity of the SRS100 (WxLxH): 2.5" x 4.3" x 7.4". "
If the WH32/WH31 housing meets these requirements, it should fit. The probe of a WH32-EP will definitely fit.
Got it. The WH31E shows dimensions of 4.75 x 1.5 x 0.6 in, which it appears would fit. My other question was about the WH32EP. If I do this, I might want to get the better sensor. Obviously the probe itself is smaller, but I would have to put probe and casing in there, wouldn't I?
Ambient:
WS 5000 (WS-5000-Array, WS-5000-Rain, WH32B, WS-5000-Console)
WH31E (Outdoor Thermo-Hygrometer sensor)
WH51RF (Refrigerator/Freezer Sensor)
Starpath:
USB baro (barometer)
Offline Rocketman
HP2550,FW 2.0.4, WS80 FW1.2.9, WH57 , WH40 , WH51, GW1100 FW2.3.4 , WN90LP FW1.4.7 wirelessly to Hongyuv HY Display, INKBIRD iAMQ-128W V1.1, WH55 x 2 , WN34D,Vector Instruments A101M & A101K , CumulusMX 4.4.5 b4088, Weather Display 10.37S 152
Offline Gyvate
maybe @Rocketman meant to put the housing of the WH32-EP into that shelter and the probe inside the SRS100LX, which could make sense.
On the other hand, the shield (and the probe) shouldn't be higher up than 2 m above ground.
What I have done is put the housing in a wetroom casing (IP65) with a transparent window used for fuses - like this I can also see the temperature/humidity on the display of the WH32-EP housing.  8-)
WS2350 1.7.0,GW1000 1.7.7,WH2650 WiFi 1.7.7,GW1100 2.3.7,GW1200 1.3.4,GW2000 3.2.1,GW3000 1.0.3,HP2550 2.0.1,5.1.9; HP3500 1.7.2,WS3800 1.3.4, WS3910 1.3.4, WN1910 1.2.4,WN1820/WN1980 1.3.5;
Ecowitt WS90, WS85, WS80, WS68, WS69, WN30, WH31,WH31-EP, WH32,WH32-EP, WH32B/WN32P, WN34D,L,S,  WN35,WH40, WH41[PM2.5], WH45, WH46D, WH51, WH55, WH57, LDS01
Blake-Larsen Sun Recorder - RPi4/weewx 4.10.2/CumulusMX 4063/MeteobridgePro 6.1,Meteobridge RPi4B-2GB,MB VM
Barani Meteoshield Pro,MetSpecRad02,SMarTCELLino;Dracal BAR20
WIKI https://meshka.eu/Ecowitt/dokuwiki
Offline Rocketman
exactly what I meant , thanks Gyvate
Offline Rocketman
Apologies
 [tup]
Offline Platokidd
  • top side land of Lincoln
I used this set up.  - https://www.amazon.com/dp/B07PK8K8S2/?coliid=I39EAEYO687A7F&colid=3GPJYW7H3VKMO&ref_=list_c_wl_gv_ov_lig_pi_dp&th=1
« Last Edit: May 12, 2025, 05:01:30 AM by Platokidd »
Plato Center Weather
Ambient
1-WS-2000 1-WS-2902A 1-WS40/RAIN 1-WH31L
1-METEOBRIDGE 1-SRX100LX
ECOWITT
1-HP2550 2-HP2560 1-GW2000
1-WS3900 1-GW3000 1-GW1100
1-WS68 1-WS80 1-WH32EP 10-WH31 2-WH40BH
1-HP10 1-WH45 1-WH46 4-WH55
1-WN30 1-WH41 6-WH51
1-DAVIS 7714
1-STRATUS
1-Fisher Barometer 1436R-22
1-Starpath Baro
PWS at 2 locations.
And Zelda The Storm Dog
Uploading to: CWOP, AWN, Ecowitt.net, Weather Underground, PWSweather.com, AWEKAS, Windy.com, WOW, MeteoMap.Cloud.
Offline jcjrogers
Thanks again for all the help! So it looks like if you separate the case from the probe, you would have to drill a hole in the SRS100LX, would you not? it also looks to me like case and probe might both fit, though I assume you don't want the probe to be touching the inside walls, but maybe that doesn't matter.
Ambient:
Starpath:
Offline Gyvate
read the SRS100LX manual on how to fix the probe  :-)
and, depending how you install it (top-down, bottom-up) have the cable run out between the elements (top or bottom) - you do not need to physically separate (disconnect, even temporarily) the housing from the cable or probe.
Maybe I misinterpreted the word "separate".
I would keep the housing outside and only the probe inside - also for better airflow.
Offline jcjrogers
I did read the manual, and it didn't mention a separate probe, specifically. It showed using cable-ties to attach a sensor case to a piece of plastic, which was then inserted into the cavity of the shield (like most of these instructions, they weren't very good). From what I can tell, you might be able to attach the case to the mounting piece, tie up the excess sensor cable, and let the probe dangle; or maybe if there is enough room, you could tie the sensor cable to the case and the case to the mounting piece, and have it all together. The cavity would have to be wide enough to allow the mounting piece, the case, and the probe/cable to all be tied together.
The instructions did mention running sensor cables, but what it showed were two thin wires which wouldn't need much gap. Going by the pictures, the probe cable with the WH32EP looks to be pretty substantial and would need a pretty big gap. The screws might be long enough to create the gap, but the gap would be big enough to allow water, dirt, wasps, etc. to get inside the shield.
Ambient:
Starpath:
Offline Platokidd
I ran the WH32EP through the side of the shield sections. This means I had to un-assemble the shield to run the WH32ep through. Then I attached it to mounting piece with zip ties, tightening just enough to hold it in place. Made loop in the cable so the probe doesn't tough anything. Then re-assembled the shield and mounted it on a 4x4 post.
It's not that difficult to do.  Sometimes, one has to think outside of the box per-say to make stuff work.
« Last Edit: May 16, 2025, 06:42:49 PM by Platokidd »
Ambient
ECOWITT
1-DAVIS 7714
1-STRATUS
1-Starpath Baro
PWS at 2 locations.
Offline Rgv20
Almost my exact same setup with my WS-5000. The Davis 7714 Shield with WN32EP(WH32_EP) Temperature and Humidity Sensor with SHT35 Probe works beautifully. I have had this setup for almost a year and a half on the full south texas sun with really good results.
I have been wanting to buy an extra WH32 EP with no luck as the 915mhz has been sold out since January. Anyone has any inside info with ecowitt? The last message I got from ecowitt was that it would be back in stock in April last month :/ My original sensor is still going strong but just wanted to have a back up one.
Offline MrM1
  • North Central Florida
    • Bethel Weather
I got mine on Amazon (US) in the Ecowitt Amazon Store back in early April.  It is listed at the WN32BS,  But it is the same as the WH32-EP.
https://www.amazon.com/dp/B0B23JG8HY?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_3
Frankenstation: Ecowitt/Ambient Weather
Gateways:  GW3000/GW1200/WS2000c
Arrays: WS85/WS-2902-ARRAY
Sensors: WH31x5/WH32/WH32-EP/WH32B/WH57/WH51/WN34BL/WFC01/WH46D
Shields: AW SRS100LX/Ecowitt RS-00001
My Station Web Pages:
Ecowitt Weather
Weather Cloud
