Author Topic: web enabled pool water temp hardware  (Read 1138 times)
Offline flyingvranch
    • KI5OMM Weather Station
« on: May 03, 2025, 01:37:31 PM »
Hey all!
I am looking for a water temp gauge that will upload data to a website. I have my own server space or I could also use a cloud based setup if necessary.
I want to monitor my pool water temps on a personal weather page either via FTP or if cloud based, I suppose I could use frames to display the cloud website within my personal website. I am unsure and uninformed about the latest tech available to do so.
Any info would be much appreciated!
Offline R.Sidetrack
Re: web enabled pool water temp hardware
« Reply #1 on: May 03, 2025, 04:24:55 PM »
Seems to me a simple solution would be to use one of the Ecowitt sensors, plus a GW1100 console/gateway and use the free Ecowitt web site. But data from the Ecowitt gateways can be uploaded to custom servers, if you want, no additional charge.
GW1100: https://shop.ecowitt.com/products/gw1100?variant=41418887856290&country=US&currency=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gad_source=1&gad_campaignid=22055434254&gclid=Cj0KCQjw_dbABhC5ARIsAAh2Z-TSQttUbDOpffI9z04R2R3tZhFSZnIKqHUaod5XEbHWA4v79-yuYU4aAlhMEALw_wcB
Inexpensive sensor: https://shop.ecowitt.com/products/wn30?_pos=1&_psq=probe&_ss=e&_v=1.0
You can spend more money on fancier devices, but there is the basic functionality.  Whatever you choose, make SURE you can control/download/capture your data for free. Don't get suckered by the vendors that want to make you pay an ongoing fee to access your data. :roll:
« Last Edit: May 03, 2025, 04:28:05 PM by R.Sidetrack »
Graham
--- Variety of 'discrete' Ecowitt devices; CumulusMX on Raspberry Pi4 ---
« Reply #2 on: May 03, 2025, 05:24:14 PM »
Thank you for the helpful info. Yes, I do want to control my own data if possible. That's why I went to the trouble to build my own website and have my own server space. I have a Davis VP2, but it is located 1/2 mile from my pool, so it's of no real use in this situation. I basically want a stand-alone water temp sensor that will send data either to my server directly, or if somewhere else - a place where my web page can access it and graph it.
« Reply #4 on: May 06, 2025, 02:47:52 PM »
I set up an Ecowitt temp gauge and gateway. It's working perfectly for my particular application. Thanks folks for the help and suggestions!  [tup]
Offline corradoutah
« Reply #5 on: June 11, 2025, 04:13:09 AM »
I ran into a similar problem after installing a pool where my Wi-Fi signal just wouldn’t reach the Ambient Weather station reliably anymore. I ended up moving the console a bit closer and used a basic Wi-Fi extender to help keep a stable connection. Sometimes even small changes in the backyard layout can mess with the signal path.
« Last Edit: June 12, 2025, 06:22:37 AM by corradoutah »
