Author Topic: Piloting radio-controlled radiators  (Read 2327 times)
Offline wxfan
« on: February 26, 2025, 02:37:08 AM »
Hi All,
I know this is a bit off topic but I am desperate to find a solution.
I have several electric radiators which are radio controlled with a remote that works on frequency 433mhz, the same as my Ecowitt setup. The problem is that ONE remote controls ALL radiators in the house. This is really undesirable for many practical and economic reasons.
I think the company who made these has closed (no wonder...) but I need to find a solution.
Obviously the remote must have a completely different data protocol than my Ecowitt hardware, but is there anything I can do to control these radiators with home connect or my Ecowitt hub? Or is there any other solution? I cannot use smart plugs everywhere because the radiators are wired directly in the wall mains, also once they are connected to the mains they are in stand-by and are only turned on with the remote. If the remote is not connected there's a physical button. You can see how this is problematic.
Any idea of how I might be able to control these radiators?
Thanks!
GW2000, WS80, WH40
Online davidmc36
  • FN25IE61IX
    • MorewoodW34
Re: Piloting radio-controlled radiators
« Reply #1 on: February 26, 2025, 03:31:04 AM »
Any chance of bypassing the physical button and connecting some IoT device to each radiator?
Offline wxfan
« Reply #2 on: February 26, 2025, 04:35:33 AM »
I think the only way in that sense would be to install it inside the wall plug, there's no room in the radiator for anything like this and no screws to access the electronics.
GW2000, WS80, WH40
Offline R.Sidetrack
« Reply #3 on: February 26, 2025, 08:01:14 AM »
I suggest posting more details of your electrical situation, including  a photo of the "plug", but if its a USA style plug something like this should work:
https://www.tp-link.com/us/home-networking/smart-plug/ep10/v1/
As its a heater, the current draw of the heater may be more than that device is rated for, so specs of the heater should be considered first, but an alternative device may be a solution. Those Kasa plugs are easy to integrate with Home Assistant or use the manufacturer's app. The plugs use wifi so you need functional 2.4GHz wifi in that part of the house for this to work.
And Home Assistant has a "generic thermostat" that can be set up to work with that plug to turn the plug/heater on/off to keep the temperature within the limits you set. It works well.
I expect that the Ecowitt IoT plugs are an alternative, but the ones I have used are the Kasa plugs linked above. I am using the  Ecowitt sensors to report the room temperature to Home Assistant.
« Last Edit: February 26, 2025, 08:15:55 AM by R.Sidetrack »
Graham
--- Variety of 'discrete' Ecowitt devices; CumulusMX on Raspberry Pi4 ---
Online davidmc36
  • FN25IE61IX
    • MorewoodW34
« Reply #4 on: February 26, 2025, 07:17:54 PM »
..... if its a USA style plug ....
..... I cannot use smart plugs everywhere because the radiators are wired directly in the wall mains, .....
This seems to be the major drawback to "Smart" devices.
Offline R.Sidetrack
« Reply #5 on: February 26, 2025, 07:49:53 PM »
Well, I was responding to his use of the word "plug", here:
A "plug" implies to me that it is removable, thus a possibility of adding a 'switch'.  A hardwired connection is more difficult, which is why I suggested a photo.
Controlling a hardwired heater is not impossible, but likely involves a suitable relay (depends on voltage and amps) plus a wifi controller, perhaps like this: https://us.shelly.com/products/shelly-plus-1pm-list-copy?srsltid=AfmBOopdCtkwd93We3UFMv7Nlkp3USSmvHn-sP14UUp-UNZsH1Pge7nu
If there is no room inside the wall, then add a box to the surface of the wall. Or replace the heater with a different model. But all options involve time, effort and money that in the end may be deemed not worthwhile.
« Last Edit: February 26, 2025, 07:54:57 PM by R.Sidetrack »
Graham
