Author Topic: Forecast  (Read 1057 times)
Offline steviebaby59
    • Empire Prairie Weather
Forecast
« on: February 17, 2025, 11:19:51 PM »
I'm getting this error at the end of every forecast. Anybody know what's going on?  It does it on McMahon and Bohler.
Offline ConligWX
  • #conligwx
    • conligwx.org
Re: Forecast
« Reply #1 on: February 18, 2025, 03:54:36 PM »
Regards Simon
Davis Vantage Pro2 Plus (6162UK) • Daytime FARS • WeatherLink Live • AirLink • PurpleAir PA-II-SD • CumulusMX • ADSB.im • Pi 4 • AirSpy mini • Uputronics Filtered 1090 Preamp
Offline broadstairs
Re: Forecast
« Reply #2 on: February 18, 2025, 04:46:46 PM »
My forecasts using McMahon data have been fine. This can happen if the file created by WXSimate is not the same as that read by WXSim, in order to check what WXSim is using to Import you have to turn off auto run to do the Import manually and check the file name. Happening on Bohler as well does point to something like this being possible.
As has been pointed out the Weather Watch forum is the best place to report issues as that forum is visited by Tom (author of WXSim) when he has time and there are quite a lot of users there (including me  ;) ).
Stuart
Re: Forecast
« Reply #3 on: February 18, 2025, 05:14:39 PM »
Seems to be working again. Don't know exactly what I did, I just kept checking and unchecking boxes on my WXSIMATE.
