Author Topic: Batch file help  (Read 1333 times)
Offline britbob
Batch file help
« on: February 07, 2025, 07:52:07 AM »
Anyone have a good understand of windows/ms batch files?
I have an old piece of Windows software that has a built in ftp scripting option on a scheduler. Unfortunately it won't work anymore because most hosts provide a secure ftp environment these days which it can't cope with!!
The software does everything I need, it dumps the created images in a folder locally on my c: drive but obviously without ftp working it won't upload them to the host via ftp.
Does anyone know how to write a windows batch file that will ftp all the images (wild card??) in the local folder to a designated folder within my hosting environment.
I can schedule the batch file every hour through windows, thus achieving what the software used to do.
Hope this makes some sense!!!
Offline swright1957
    • Hytheweather.co.uk
Re: Batch file help
« Reply #1 on: February 07, 2025, 08:45:42 AM »
Hi
Winscp ftp program can schedule ftp uploads to a website host.  So if your batch file loads everything to a folder then Winscp could upload them for you.
Download it and give it a try.
https://winscp.net/eng/docs/guide_schedule
"anything's possible with the weather"
Offline 92merc
  • BismarckWeather.net
Re: Batch file help
« Reply #2 on: February 07, 2025, 08:56:05 AM »
I'm also using WinSCP with the linked method. It's worked flawless for me.
Offline britbob
Re: Batch file help
« Reply #3 on: February 07, 2025, 10:52:12 AM »
Thanks guys, and it can capture all the .png's in a folder and upload them such as wild card style?
I'll have a look as the docs and figure out how to write the script/commands to make it happen.
Offline 92merc
Re: Batch file help
« Reply #4 on: February 07, 2025, 12:28:50 PM »
Here is my command, with login edited.  I'm sure you could change that to a wild card, although I haven't tested it.
_______________________________________________________
open ftp://cumulusmx%40bismarckweather.net:password@bismarckweather.net/
put C:\CumulusMX\data\dayfile.txt dayfile.txt
# Your command 2
exit
