Author Topic: Can Wittboy firmware be updated via Wine?  (Read 528 times)
Offline BaseLine
« on: August 05, 2022, 10:38:55 AM »
I do not have MS Windows. Dropped MS 15 years ago and I never needed it again.
Now, I like to upgrade the new Wittboy firmware and it is MS Windows only.  :-x
Has anyone successfully used it with Wine?
Sun cooked nothingburger of climate change hysteria with a side order of peak-oil nonsense fries.
Offline davidefa
Re: Can Wittboy firmware be updated via Wine?
« Reply #1 on: August 05, 2022, 11:01:30 AM »
It should work under linux ( on ubuntu, for example, you should use the dfu-util package ): https://community.st.com/s/question/0D50X00009XkXEBSA3/dfusedemo-on-ubuntu-using-wine
Offline broadstairs
« Reply #2 on: August 05, 2022, 11:04:30 AM »
I have not tried Wine but I do have W7 running under Virtualbox on Linux and it works with my WS80 on that so that is another option if you have a W7 system to install.
Stuart
Offline davidefa
« Reply #3 on: August 05, 2022, 11:25:03 AM »
Microsoft should still have a 90 day trial version of Win 10: https://info.microsoft.com/ww-landing-windows-10-enterprise.html
Offline broadstairs
« Reply #4 on: August 05, 2022, 12:07:56 PM »
I just checked and the Linux packages are available for openSUSE as well, and I expect other distros as well.
Stuart
Offline Gyvate
« Reply #5 on: August 05, 2022, 12:14:40 PM »
- Windows 7-11 in any type of Virtual Machine (VM) should work [USB port and driver available of course], also in Docker
- Windows 11 (preview ARM64) installed on a RaspberryPi4B - 4GB will work
or maybe just borrow a Windows laptop from a friend or acquaintance for the update process  ;)
If WineHQ provides the proper USB driver, it could also work ....
« Last Edit: August 05, 2022, 12:19:32 PM by Gyvate »
