Weather Software > WeatherLink/weatherlink.com by Davis Instruments
Davis WL will not produce images or graphs
(1/4) > >>
chief-david:
New Davis Vantage Pro 6163
Vantage Vue console (need to look at firmware)
DIY data logger
VVP
Weatherlink 6.5
CP210x USB to Serial converter
Also running Weatherdisplay-for the main info
I would like Weatherlink to create a few graphs, TSHW, Dew point, a few others. But it wont. It will download the info, but stops. I get these errors.
It will not work with VVP. Running tcp/ip.
It will work if I am not going through VVP.
I also took out the batteries, pulled the logger, and all the other stuff to reset it.
Garth has been a big help here, but I dont want to keep bugging him. He is busy too.
Any solutions are great.  I am also working on setting up VPSE
Garth Bock:
Could you list the steps that you take to produce this error ?
I have 2 test setups...
1) DIY Logger and cable on an Envoy running 3.88 firmware with VVPro and VPSE. WL is on a TCP channel
2) Davis Logger on an Envoy running 3.88 firmware on VVPro and VPSE. WL on a TCP channel.
Walk me through the steps of generating the graphs. I would like to see if my test set up will produce the same results. I can click on Plot and Strip charts and those work fine.
I know it works fine without VVPro and VPSE, but it could still be something with the cable or DIY logger in combination with the software.
chief-david:
That is about it. just trying to do this.
Internet settings....
hit ok.
It downloads, then stops and will not produce any of this. I do have to go in tomorrow so I can see the firmware on the console.
Wondering if I installed the correct serial to USB converter, But it both programs are working well.  or if there is some .dll that the computer does not have.
Mattk:
What does your Setup>Internet Settings window look like?
chief-david:
I dont have it set at a time because it is not working
[#] Next page
