Weather Station Hardware > LaCrosse Technologies/Hyundai
TX60U-IT Weather Alert Sensor connect with La Crosse View
<< < (2/2)
bobby2478:
ok so it's visible in the chart, but i've heard elsewhere that it's not visible from the mobile app dashboard? Also doesn't ecowitt only retain data for 2 years unless you setup your own server to store the data locally?
R.Sidetrack:
If you ever find yourself in a situation where your only option to fix a problem is to reset the device, its quite likely that data in the LaCrosse system will be lost. That isn't a knock on LaCrosse, but its pretty typical across the board. If data retention is important to you, storing it independently is the best option.
[*] Previous page
