Author Topic: GW1100 New device Coming!  (Read 5196 times)
Offline Mandrake
« on: June 10, 2021, 03:50:28 AM »
Some more breaking news from Ecowitt and Fine Offset!
The engineering teams have been well busy lately!
They are developing the next generation of the GW1000 at present. The stand out change for this version is that it will also feature a web interface to allow for configuration of the settings/Wifi etc
Whether any of the other wished for changes will make it such as sd card backup options for local data storage are not yet being revealed. (at least to me!)
G1ZFO
Ecowitt GW2000 (Test)
Ecowitt WS90 Wittboy - Test
Ecowitt WH41 PM2.5 AQM Sensor
Ecowitt WN35 Leaf Moisture
Offline mcrossley
    • Wilmslow Astro
Re: GW1100 New device Coming!
« Reply #1 on: June 10, 2021, 04:32:20 AM »
Web interface is interesting - how do you connect to the network to get the web interface, WiFi Direct I suppose?
For me the biggie will be adding the logger capability - along with an API to access it. Please please please in JSON format not binary!
Offline broadstairs
« Reply #2 on: June 10, 2021, 06:47:05 AM »
Just my luck again  :mad: When I purchased my VP1 within a few months the VP2 came out, now having got my GW1003 system they are about to replace the GW1000 with something better! Be good if they offer a discount to people who recently purchased the old one but some how I doubt it.
Stuart
Offline Mandrake
« Reply #3 on: June 10, 2021, 09:23:02 AM »
The GW1000 is a very low cost part of your overall system.
The price to upgrade a new model is likely to be around ~$50 USD or less. So given that, I would not get overly upset and as stated at time it is not overly clear just how much of an evolution the new model will bring. Also this is early news and it may well be many many months before it is released to the public!!
G1ZFO
Offline zoomx
« Reply #4 on: June 10, 2021, 11:53:08 AM »
The GW1000 is based on ESP8266 an MCU that is very common among arduino community. You can find many examples about web interfaces on this device.
ESP8266 can be configured as an Access Point, so you connect to it and then usually there is a captive portal so everithing you write as URL you will go to the web server, otherwise IP 192.168.4.1 is used.
Maybe they will shift to ESP32? It is similar to ESP8266 but has more pins, two cores and is able to drive a little webcam the ESP32-CAM. IT has also bluetooth but not at tha same time of WiFi.
Offline broadstairs
« Reply #5 on: June 10, 2021, 12:11:13 PM »
No it's just that I feel I jinx it when buying something new and it soon gets replaced  ;)
Stuart
Offline Rover1822
« Reply #6 on: June 10, 2021, 12:21:54 PM »
Stuart
Yeah you don't have 4 GW1000s :), I don't see myself upgrading as an early adopter :)
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
  WittBoy WS90 + GW2000
  WS90 (other one) + GW1100
Personal Sites: Weather Cam
Offline giusCB
  • www.turismometeo.it
« Reply #7 on: June 10, 2021, 01:18:10 PM »
yeah, a data logger function like weatherlink live would be very interesting  :lol:
www.turismometeo.it
Offline WA4OPQ
  • 4 stations: 2902 array, GW1000, 3 on Meteobridge
« Reply #8 on: June 13, 2021, 10:22:02 PM »
The web interface will be handy for me. I have two remote sites that I can visit the raspberry pi with VNC. That means that I will be able to check and adjust the device and update the firmware without having to travel to the site.
(I have six GW1000s already)
« Last Edit: June 13, 2021, 10:24:45 PM by WA4OPQ »
Offline Mattk
« Reply #9 on: June 13, 2021, 10:59:02 PM »
What? Another non local cloud based system with a possible subscription to support? No Thanks.
Offline waiukuweather
« Reply #10 on: June 14, 2021, 12:24:45 AM »
cloud based is the future though
you either get with the times or you don't
Offline broadstairs
« Reply #11 on: June 14, 2021, 03:21:34 AM »
Cloud is OK but it only works if you have 100% connectivity plus so much is hacked these days you need to spread the risk which in turn expands the hacking risk. The only zero risk is no connectivity   ;)
Stuart
Offline Gyvate
« Reply #12 on: June 14, 2021, 04:49:01 AM »
Stuart
As long as it works on my personal (local network) cloud ... 8-)
Offline WA4OPQ
« Reply #13 on: June 18, 2021, 04:30:06 PM »
Ambient has been talking about a replacement for the ObserverIP for some time.
I'd bet that this will be it.
Offline ghislain
« Reply #14 on: June 24, 2021, 05:43:00 AM »
Is there any chance that there will be the possibility to use multiple customized upload profiles through Ws View?
I am stuck between a rock and a hard place wanting to simultaneously sending data to PWSWeather and HomeAssistant....
Ecowitt GW1000
Ecowitt WH32 Outdoor Temp/Humidity Sensor
Davis 7714 Radiation Shield
Froggit DP300 (Ecowitt WS68) Anemometer with UV/Light Sensor
Froggit DP80 (Ecowitt WH40) Rain Gauge
Ecowitt WH51 x2 Soil Moisture Sensors
Ecowitt WH57 Lightning Detector
Ecowitt WH41 Outdoor PM2.5 Air Quality Sensor
Ecowitt WH45 Indoor CO2/PM2.5/PM10 Air Quality Sensor
Offline Gyvate
« Reply #15 on: June 24, 2021, 06:35:37 AM »
No idea - but
you may want to look into the FOSHKplugin from olicat
https://www.wxforum.net/index.php?topic=39625.0
this little tool allows to send (distribute, forward) data to up to 50 (afaik) different parties from one single GW1000 (or other Ecowitt [clone] console).
And it can do many more things.
Of course it needs to run on some server, e.g. a Raspberry Pi or a NAS server.
Offline ghislain
« Reply #16 on: June 24, 2021, 06:46:27 AM »
Brilliant, thank you Gyvate, I'll look into this, I can easily setup another VM and run it from there.
First some more thorough reading to do  [tup]
Ecowitt GW1000
Offline K7RMK
    • East Wilson Weather
« Reply #17 on: July 22, 2021, 11:24:23 AM »
A web interface and ethernet connection are my most wanted features.
Ecowitt GW2000 + Meteobridge on RPI 4B
Ecowitt HP2551-C Display Console
Ecowitt WH32-EP Outdoor Temp/Humidity Sensor + MeteoShield Pro Radiation Shield
Ecowitt WS68 Anemometer
Ecowitt WH40 Rain Gauge
Ecowitt WH43 Indoor PM2.5 Air Quality Sensor
Ecowitt WH31 x4 Temp/Humidity Sensors
Ecowitt WH51 Soil Moisture Sensor
Ecowitt WH34S Soil Temperature Sensor
Ecowitt WN35 x2 Leaf Wetness Sensors
Offline kheller2
« Reply #18 on: July 22, 2021, 12:58:31 PM »
Like the old ObserverIP?
Well, they got the web interface in this one.  You still have to configure it by wifi but no longer need the app to do so.
Ambient Arrays: WH65B
Ecowitt: HP2551BU, GW1000B(dead), GW1100B(2), GW2000B
Ecowitt Sensors: WH51, WN34BL, WN34(2), WH31, WH41, WH40
Offline Rover1822
« Reply #19 on: July 22, 2021, 01:01:16 PM »
I think what would be nice is if it provided a web interface for local viewing of data on your own network, as opposed to just configuration. I know I got to stop daydreaming
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
Offline K7RMK
« Reply #20 on: July 22, 2021, 01:06:01 PM »
WiFi is a silly way to connect a server to the network. No serious IT guy does this. WiFi is for portable devices and convenience sake, not servers. For power outages, I have to have to have my wireless access point on a battery backup rather than just my router and modem in order to keep my weather station going.
Offline Rover1822
« Reply #21 on: July 22, 2021, 01:24:04 PM »
Not going to argue the points made, as I agree with them and consider myself to be a serious IT guy. But in this case, as the unit measures indoor temp/humidity/pressure , location of placement is important. Few residential abodes have ethernet jacks all over the place (if any), but they do have power outlets, so WIFI makes sense.  It is unfortunate that the unit itself does not have a rudimentary backup for small power outages, but, for the price and feature list, I don't complain too much.
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
Offline kheller2
« Reply #22 on: July 22, 2021, 02:31:09 PM »
Skimming the manual, there is a live data tab screen.
Offline tedroche
  • Semi-retired, novice weather station operator
  • Weather Observer, CoCoRaHS, Storm Spotter
    • Contoocook Village North
« Reply #23 on: July 22, 2021, 04:14:16 PM »
I didn't realize it was live on the Ecowitt.com website for ordering as of yesterday.
https://www.ecowitt.com/shop/goodsPage/1/31
Ecowitt GW1100, HP3501 WH32B WN32BS WH31 WH41 WH40B WS68BN
WeeWx Seasons on Raspian Buster Web site
WU: KNHHOPKI09 CWOP: GW0103 and WOW
CoCoRaHS: NH-MR-68 PWSWeather
Offline Phil23
    • Phil's Backyard
« Reply #24 on: July 22, 2021, 07:18:51 PM »
What's your experience with orders from them?
I have one that was placed on 12/07/21 which is still listing as Unshipped.
So it's now had that status for 12 days.
Phil.
