Weather Software > What Weather Software should I use/buy?
Can't find software ?
(1/1)
REDEX:
I have a Pro-Signal PWS PSG04173. Connection is only by WiFi. I cannot find any software to display the station data on the screen of my PC. Did not have this problem with an earlier system that had a USB connection.
I have uploaded to Wunderground Station ICOLCH77 and everything works fine, but it does not "mirror" all of the data shown on the station display.
During set-up it displays as an "EasyWeather" model. I have the ISP address for the station but it "refuses to connect"
I configured the station by using "WS View" as an android mobile app. There are no references to software or using a PC in the instructions.
One thing I miss is that previous desktop displays had the option of "mixing" metric and Imperial. I choose to use Imperial for everything except the temperature which I only really relate to in Centigrade. Being at school in 1965 meant that metric units were coming into fashion however I had already mastered measurements in Imperial except the temperature !! I am completely fluent in metric but still mentally convert to gallons, feet, lbs when it suits. For example if I measure a length at 1346mm I will opt to write down 53 inches, its faster and easier. I see the world in Imperial and Metric, apart from temperature !!! My knowledge of Fahrenheit is 32F=0C 61F=16C and 212F=100C but I have no idea how warm or hot 88F is !!!
Thanks Neil
galfert:
I recommend that you buy an Ecowitt GW1000. Make sure to match the frequency of your station when ordering (433, 868, or 915). That will then give you the ability run Cumulus MX, Meteobridge, Weather-Display, or WeeWX. I suggest running any of these on a Raspberry Pi. Then you can pull up the nice interface on your computer.
REDEX:
Hi Galfert,
thanks for the reply. However it does not really help me with the software problem for the weather station I have just bought and fitted.
Regards Neil
Jasiu:
Can't help with the software, but for F <-> C, I just keep milestones in my head based on a delta of 10C equals 18F.
0C = 32F
10C = 50F
20C = 68F
30C = 86F
So in the example you give, I know 88F is about 31C without having to do any sort of conversion.
galfert:
--- Quote from: REDEX on February 27, 2021, 05:59:32 AM ---Hi Galfert,
Regards Neil
--- End quote ---
Adding the GW1000 does help you with your station. The GW1000 will pick up all your station's sensors and allow you the use of many software options. The GW1000 is less than $40.
