Author Topic: NOAA/EC All Hazards Radio (147 Stations, 178 Streams)  (Read 2088 times)
Offline ed_heaton
    • Atglen Borough Weather Observatory
« on: February 22, 2020, 06:54:02 AM »
Anyone else having issues with the Live NOAA weather radio.org?  I am unable to get any of my local feeds to play...
TIA...
Offline tmabell
    • Mishawaka Weather
Re: NOAA/EC All Hazards Radio (147 Stations, 178 Streams)
« Reply #1 on: February 22, 2020, 09:08:03 AM »
There is an issue with the current version of Chrome.  Try another browser.
Offline 92merc
  • BismarckWeather.net
  • Moderator
« Reply #2 on: February 22, 2020, 10:55:00 AM »
It appears to be an issue with Chrome on Android.  My Chrome for Windows is working...
EDIT:  Looks like I spoke too soon.  My Chrome must have updated just now.  My version 80 isn't working either now...
« Last Edit: February 22, 2020, 10:57:12 AM by 92merc »
Offline 92merc
  • Moderator
« Reply #3 on: February 22, 2020, 10:59:29 AM »
I have the "new" Edge installed, which is Chromium based.  That is at version 80.0.361.57.  That still works.
But Chrome 80.0.3987.116 does not work.
« Reply #4 on: February 22, 2020, 11:43:23 AM »
Now, Chrome 80 autoupgrades mixed audio and video resources in HTTPS sites by rewriting URLs to HTTPS without falling back to HTTP when secure content is not available. If they fail to load over HTTPS, Chrome will block them by default. Mixed images are still allowed to load, but they will cause Chrome to mark the page as “Not Secure” in the omnibox.
Unfortunately, wxradio.dyndns.org (the main Icecast server for noaaweatherradio.org) is http-only, as are most privately provided streams.  With noaaweatherradio.org forcing https, none of the streams will play directly (or via the radio player script if run on a https site) with Chrome 80.  Sigh.
Offline ed_heaton
« Reply #5 on: February 22, 2020, 12:02:32 PM »
Like some of the folks indicated it will run on Firefox (unfortunately I don't use Firefox - I guess I'll start) and if you are determined it will run on an older version (Chrome 79).  You just have to turn the autoupdates off and reinstall the older version. I know it's not idea by any means but as a workaround...
Thanks for the great explanation Ken! I'm going to post your reply to the Google support team...
« Last Edit: February 22, 2020, 03:29:42 PM by ed_heaton »
Offline 92merc
  • Moderator
« Reply #6 on: February 23, 2020, 12:59:47 PM »
The part that annoys me, is that if you go directly to the link via Chrome, it does work.  Even though it isn't HTTPS.  So Google is doing something really stupid...
Offline Cutty Sark Sailor
  • Moderator
« Last Edit: February 23, 2020, 01:49:54 PM by Cutty Sark Sailor »
Offline ed_heaton
« Reply #8 on: February 24, 2020, 01:21:49 PM »
Thanks Cutty and that fixed my issue for me!
Offline 92merc
  • Moderator
« Reply #9 on: February 24, 2020, 01:24:25 PM »
Yeah, I was able to follow that for the PC instructions to.   But I can't find those settings on my phone Chrome version.
Offline 92merc
  • Moderator
« Reply #10 on: February 24, 2020, 02:55:09 PM »
I've been trying to play with the .htacess file.  There is supposed to be a way you can change that so that all of your files, except one, will be forced to HTTPS.  The other one could stay HTTP.
My theory is that if the wxradio.php page isn't secure, you will no longer have mixed security and Chrome would quit complaining.   Just a short term fix.  But in theory it should work.
Maybe someone here with more experience can figure that out?
Offline NWROrg Team
  • Save A Life
  • Moderator
« Reply #11 on: February 26, 2020, 08:14:41 AM »
A possible work around. for the non-ssl streams,. etc.
First, see special version of this script testing at
https://noaaweatherradio.org/wxradio-5/radios.php
...this (Development V6) is operating with HTTPS and should have same stream issues.
Now, try this:
https://noaaweatherradio.org/wxradio-6NS/radios.php
...(Development V6 - NS) is operating with the following mod, and hopefully no stream issues.
also note that the 'nav' icons switch back to 'ssl'....**see below
Copy your "radios.php'
rename the copy to (e.g.) "radiosNS.php'
(for (Non Secure) heh.  in same folder..
In 'head' of your current 'radios.php'
add (with appropriate direct URL of 'radiosNS.php")
Stand-aloen HTML 5
<meta http-equiv="Refresh" content="1; url=http://YourDomainpath to/radiosNS.php">Saratoga Template\
<meta http-equiv="Refresh" content="1; url=http://YourDomainpath to/radiosNS.php" />
That will direct browser to 'non-ssl' after one second.
One reason for this: simple chnage by remove the meta should the 90+ stream sources from WxRadio.DynDns go SSL.
If you have any "local" links to your SSL domain pages on the new 'radiosNS.php' ,
or added to"NWR-radios-inc.php" e.g. (as in the aove 2 dev pages),
 they should probably be changed to
ABSOLUTE, with https,
or browsers may may not 'revert' to your SSL pages, when you want to go back to 'ssl' pages...
e.g.
href="../index.php" ...change to
<li> href="https://whatever.domain etc/index.php" ...
-Mike-
« Last Edit: February 26, 2020, 09:09:02 AM by NWROrg Team »
Offline 92merc
  • Moderator
« Reply #12 on: February 26, 2020, 10:24:42 AM »
I gave that a try.  I don't think it works with my .htaccess forced redirect to HTTPS.
