Here is the method I use for an external antenna on the 2902 array. I've done two so far and starting on my third.
For tools you will need a good soldering iron (not soldering gun), solder wick, small screwdrivers, needle nose pliers and flush cutters. You will also need a Dremel moto tool or equivalent and a crescent wrench.
You will be using the solder wick to remove solder from the antenna hole. If you have not previously done this then this is not a good time to learn. Please find someone near you to help with your soldering.
Also used are about 12.5 inches of RG-174 miniature coax and a single hole N connector. I will provide Amazon part numbers at the conclusion of this instruction.
Our first step is disassembly. Remove the wind vane and cups. Keep all your parts and screws in plastic bags.
In this photo are four screw holes on right. They use different phillips screws, I believe they are called #1 and #2. Before you start make sure you have the correct screwdrivers. Then remove all the phillips screws and the wind end pieces (two small connectors). Also remove the rain cup and temp assembly; It requires cutting the rubber shrink tube and very carefully pulling out the connector.
