Thanks! Yes I'm anxious to get a good snowfall now!
I agree about making the inch lines bolder. I actually was going to do that this time around but was too anxious to get it out there (plus with this thaw we are in right now I figured it was now or never to get the metal stake I have it connected to in our frozen ground. Lol!). Very good suggestion though and definitely something I'll likely do during the summer before I get it back out there for next snow season. I did notice that if you right click on the webcam image itself and select 'open image in new tab' it will pull up a larger version of the image with the option to zoom in a bit, which definitely makes it easier to see. I still like the suggestion for next season however!
I plan to use it to monitor snowfall and snow depth on top of doing my normal measurements with the ruler/yard stick each time it snows. It's kind of like a back up monitoring method for those times when I'm not home or not able to get out there right away to take measurements.
The camera does have an IR light so it should be viewable at night as well. I'm actually anxious to see how it looks at night when it gets dark later this evening. My guess is the bold line concept will come into play more so at night with the IR vision, but I guess we'll see later today!
The gauge is roughly 10 ft from the camera, and is not zoomed in at all so for this reason I believe it should still be very viewable during snowfall events even on a static image. Again with this point however it'll be a 'time will tell' kind of thing because I have yet to see how it actually looks with this new setup during snowfall.
Thanks Dale for the comments and suggestions! Much appreciated!
- Matt
