Hi!
Installed a new Davis Airlink with the weewx extension, smooth install all went well for the first 24 hrs, and after that I keep getting this error no Mather what I do.... Anyone with an insight to what the problem may be?
Aug 23 13:12:23 WeeWx-APRS weewx[9419] INFO user.airlink: collect_data: Attempt to fetch from: 10.36.50.218 failed: HTTPConnectionPool(host='10.36.50.218', port=80): Max retries exceeded with url: /v1/current_conditions (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0x704d9268>, 'Connection to 10.36.50.218 timed out. (connect timeout=2)')).
Aug 23 13:12:23 WeeWx-APRS weewx[9419] ERROR user.airlink: Could not get concentrations from any source.
Aug 23 13:12:30 WeeWx-APRS weewx[9419] INFO user.airlink: collect_data: Attempt to fetch from: 10.36.50.218 failed: HTTPConnectionPool(host='10.36.50.218', port=80): Max retries exceeded with url: /v1/current_conditions (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0x762a68b0>, 'Connection to 10.36.50.218 timed out. (connect timeout=2)')).
Aug 23 13:12:30 WeeWx-APRS weewx[9419] ERROR user.airlink: Could not get concentrations from any source.
Aug 23 13:12:37 WeeWx-APRS weewx[9419] INFO user.airlink: collect_data: Attempt to fetch from: 10.36.50.218 failed: HTTPConnectionPool(host='10.36.50.218', port=80): Max retries exceeded with url: /v1/current_conditions (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0x762a6358>, 'Connection to 10.36.50.218 timed out. (connect timeout=2)')).
Aug 23 13:12:37 WeeWx-APRS weewx[9419] ERROR user.airlink: Could not get concentrations from any source.
Aug 23 13:12:44 WeeWx-APRS weewx[9419] INFO user.airlink: collect_data: Attempt to fetch from: 10.36.50.218 failed: HTTPConnectionPool(host='10.36.50.218', port=80): Max retries exceeded with url: /v1/current_conditions (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0x704d9400>, 'Connection to 10.36.50.218 timed out. (connect timeout=2)')).
Aug 23 13:12:44 WeeWx-APRS weewx[9419] ERROR user.airlink: Could not get concentrations from any source.
Aug 23 13:12:51 WeeWx-APRS weewx[9419] INFO user.airlink: collect_data: Attempt to fetch from: 10.36.50.218 failed: HTTPConnectionPool(host='10.36.50.218', port=80): Max retries exceeded with url: /v1/current_conditions (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0x704d9868>, 'Connection to 10.36.50.218 timed out. (connect timeout=2)')).
Aug 23 13:12:51 WeeWx-APRS weewx[9419] ERROR user.airlink: Could not get concentrations from any source.
Aug 23 13:12:58 WeeWx-APRS weewx[9419] INFO user.airlink: collect_data: Attempt to fetch from: 10.36.50.218 failed: HTTPConnectionPool(host='10.36.50.218', port=80): Max retries exceeded with url: /v1/current_conditions (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0x762a7f88>, 'Connection to 10.36.50.218 timed out. (connect timeout=2)')).
Aug 23 13:12:58 WeeWx-APRS weewx[9419] ERROR user.airlink: Could not get concentrations from any source.
Max retries exceededAug 23 13:13:05 WeeWx-APRS weewx[9419] INFO user.airlink: collect_data: Attempt to fetch from: 10.36.50.218 failed: HTTPConnectionPool(host='10.36.50.218', port=80): Max retries exceeded with url: /v1/current_conditions (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0x7045bd48>, 'Connection to 10.36.50.218 timed out. (connect timeout=2)')).
Aug 23 13:13:05 WeeWx-APRS weewx[9419] ERROR user.airlink: Could not get concentrations from any source.
Raspberry Pi V3 with weewx 4.10.2 and current os and firmware for the PI.
