Author Topic: Weather Underground problems at night  (Read 1872 times)
Offline TOMeteo
« on: February 04, 2020, 01:22:11 AM »
Hello, my English is not so good, but i try to do my best :-)
Every night at 01:00 is WU ofline, but Weathercloud not.
What is the problem??
Thank you so much
Tom from Belgium
Re: Weather Underground problems at night
« Reply #1 on: February 04, 2020, 06:00:53 AM »
What is your station brand and model? Are you using just station hardware to upload or are you using some software? It might help to know what is your WU station ID.
Also at 1 AM when you go offline, how long is it gone offline for? When does it come back?
Offline wvdkuil
  • Wim van der kuil
« Reply #2 on: February 04, 2020, 06:27:35 AM »
Thank you so much
Tom from Belgium
When I check your WU Dashboard, I see continuous uploads, also around 1:00 AM  CET = 24:00 UTC
https://www.wunderground.com/dashboard/pws/IIZEGEM4/table/2020-02-3/2020-02-3/daily
What is exactly your "offline" problem?
Maybe the databases need some time to switch to a new day around 24:00 UTC, but i do not see any gaps in the uploads.
There are 2 Dutch forums you can post questions in your native language also:
1. The Het Weer Actueel Forum
2. The Leuven-Template forum
« Last Edit: February 04, 2020, 06:31:55 AM by wvdkuil »
« Reply #3 on: February 04, 2020, 06:51:39 AM »
How did you find Tom's WU ID or map location? This was his first post so there are no other clues. His forum location has his town but no map location. In both WU and WeatherCloud there are several stations in that town.??? I don't know how you did that?
Offline wvdkuil
  • Wim van der kuil
« Reply #4 on: February 04, 2020, 07:50:34 AM »
I could be mistaken, but he I thought I remembered him from using the  Leuven-Template.
At least we can check, if he has another account, if that other account has different problems.
But no other account IIZEGEMn was active.
I found similar problems with no upload between 24:00 UTC - 10:00 UTC, will make the circle larger
https://www.wunderground.com/dashboard/pws/IIZEGE8/graph/2020-02-3/2020-02-3/daily  => EasyWeatherV1.4.2
https://www.wunderground.com/dashboard/pws/IIZEGE6/graph/2020-02-3/2020-02-3/daily
=> Ambient Weather WS-2902 EasyWeatherV1.4.0
https://www.wunderground.com/dashboard/pws/IIZEGE9/graph/2020-02-3/2020-02-3/daily
=> Ambient Weather WS-2000 EasyWeatherV1.4.2
« Last Edit: February 04, 2020, 08:14:11 AM by wvdkuil »
Offline TOMeteo
« Reply #5 on: February 04, 2020, 08:00:45 AM »
Offline wvdkuil
  • Wim van der kuil
« Reply #6 on: February 04, 2020, 08:01:46 AM »
Mu station is https://www.wunderground.com/dashboard/pws/IIZEGE9
All the ones I found use EasyWeather, is IIZEGE9 also using that, or is it some default value?
Offline TOMeteo
« Reply #7 on: February 04, 2020, 08:04:15 AM »
Standaart Wim
Offline wvdkuil
  • Wim van der kuil
« Reply #8 on: February 04, 2020, 08:10:08 AM »
Standaart Wim
IIZEGE1 and IIZEGE2 use EasyWeatherV1.3.2 according to WU.
They seems to upload OK in the night.
« Reply #9 on: February 04, 2020, 08:28:26 AM »
Looks to me like the super capacitor is not making it through the night. Depending on station model it is either using a super capacitor or rechargeable batteries. In either case I think they need to be replaced.
What model station do you have? Some Fine Offset clones use a super capacitor (the newer ones). The older models use rechargeable batteries.
Offline wvdkuil
  • Wim van der kuil
« Reply #10 on: February 04, 2020, 08:39:26 AM »
Could be, but three stations close to each other, same period black-out at WU, but still uploading to WeatherCloud?
I checked the uploads for all stations in IZEGEM to WeatherCloud and all have 24/24 uploads with slightly different values and graphs. So all 5 local stations there  are correctly uploading to WeatherCloud.
Using the WU-stations-page there are 3 stations NOT uploading to WU from 01:00 CET to 11:00 CET.
Maybe there is a setting in EasyWeather for stopping uploads?
Offline wvdkuil
  • Wim van der kuil
« Reply #11 on: February 05, 2020, 04:44:19 AM »
I found two other  WU sites with the same problem, in the same "small" area of Belgium and using EasyWeatherV1.4.n
https://www.wunderground.com/dashboard/pws/ISTADEN3
https://www.wunderground.com/dashboard/pws/IHOUTH1
It are 5 stations which are off-line from 24:00 UTC to 10:00 UTC
Some commonality must be found between those stations.
Maybe you all used the same shop to buy these devices ?
or used the same person to setup those weather-stations ?
You all use EasyWeatherV1.4.n, maybe try to upgrade to latest version or to EasyWeatherV1.3.n ?
There are dozens of stations still uploading in the same region, but they use other SW-versions.
Otherwise you should contact WU with those 5 station ID's and let them check out.
« Last Edit: February 05, 2020, 05:30:42 AM by wvdkuil »
Offline TOMeteo
« Reply #12 on: February 05, 2020, 07:22:05 AM »
Last night it was again offline :-( :mad: #-o
« Reply #13 on: February 05, 2020, 08:22:35 AM »
What model is it?
How long have you had this station?
Have you replaced batteries?
Offline wvdkuil
  • Wim van der kuil
« Reply #14 on: February 05, 2020, 08:36:18 AM »
What model is it?
I checked those stations this morning at 09:00 => all off-line for WU. The OP station was Ok at weatherCloud.
All 5 stations in the same area rermained offline from WU  from 01:00 CET to 11:00 CET
But were still continuously uploading to other websites such as WeatherCloud.
Which kind of battery problem would occur at all 5 stations at exactly the same time-frame ?
And at the same time the failing batteries should not affect the upload of weather-values to WeatherCloud?
There were also no "flat-lines" in the graphs at WeatherCloud.
It could be that WU is testing their upload-servers in that period. There are enough topics about that.
As WU is moving back to their old upload-server it is important to check tomorrow morning if they are again off-line.
If so, someone with good English should post a question on the FaceBook discussion how this can happen.
Again my questions to @TOMeteo :
Maybe you 5 stations used the same shop to buy these devices ?
or you used the same person to setup those weather-stations ?
IN HET NEDERLANDS (IN DUTCH)   Nogmaals mijn vragen aan @TOMeteo:
Misschien hebben deze 5 stations dezelfde winkel gebruikt om de apparaten te kopen?
of hebben jullie dezelfde persoon gebruikt om die weerstations in te stellen?
Jullie gebruiken allemaal EasyWeatherV1.4.n,
misschien kunt u proberen te upgraden naar de nieuwste versie of naar EasyWeatherV1.3.n?
« Last Edit: February 05, 2020, 08:41:39 AM by wvdkuil »
« Reply #15 on: February 05, 2020, 10:05:53 AM »
Okay, I agree battery or super capacitor is unlikely due to WeatherCloud working.
I agree that ensuring that the latest firmware is installed as that could be the culprit.
Easyweather is Fine Offset clone hardware firmware or older PC software for some USB models. It would still be good to know what model we are dealing with.
Offline TOMeteo
« Reply #16 on: February 05, 2020, 01:13:36 PM »
This is the answer from WU:
Hi, Tom!
Please feel free to write in whatever language is most comfortable for you.  French is just fine for me!
There is a problem that seems to be affecting Ambient stations.  The engineers are trying to identify and fix the problem.  It's apparently a thorny issue.  I will let you know more when I hear anything.  Feel free to poke me if you want an update.
Thank you for your patience!
--Victoria
Offline wvdkuil
  • Wim van der kuil
« Reply #17 on: February 06, 2020, 02:44:12 AM »
All good now. This morning (FEB 6, 09:00 CET) all 5 stations are correctly reporting to WU.
The old WU-servers are doing their job.
We only have to keep our fingers crossed if the manufacturer will update the upload software.
