Author Topic: get-meteoalarm-warning-inc.php  (Read 2541 times)
Offline Axelvold
    • Axelvold's weather and photo
« on: July 18, 2012, 01:23:48 PM »
I use this on my frontpage to display weather warnings, but suddenly today it stopped working and I cant figure out why.
Any suggestions?
script is attached.
Lars Magnusson
Axelvold / Sweden
55° 57' 41" N / 13° 6' 1" E
Offline Axelvold
Re: get-meteoalarm-warning-inc.php
« Reply #1 on: July 18, 2012, 01:57:42 PM »
I did find this change in the cache file.
They changed from this
<div class="warnbox wb1">
to this
<div class="warnbox awt nt l l2">
Could it be this that caused this script to stop working?
Lars Magnusson
Axelvold / Sweden
« Reply #2 on: July 18, 2012, 05:23:45 PM »
Yep, that and a few other changes in the meteoalarm.eu website.
I've updated the script to V2.08 - 18-Jul-2012 to address the issues.
V3 template users can use the update tool (18-Jul-2012, Base-World) to get the script.
V2 template users/standalone can download from the script page
Best regards,
Ken
Offline Axelvold
« Reply #3 on: July 19, 2012, 12:51:22 AM »
Thanks Ken
I just have one small problem, can't get characters like Å Ä Ö to show up.
Lars Magnusson
Axelvold / Sweden
Offline Axelvold
« Reply #4 on: July 19, 2012, 02:28:58 AM »
the issue is resolved.
Did change ISO-8859-1 to utf-8
Lars Magnusson
Axelvold / Sweden
Offline jdee
    • Mayo Weather
« Reply #5 on: July 19, 2012, 03:03:30 AM »
thank you gents - I had the same problem.
« Reply #6 on: July 19, 2012, 12:34:38 PM »
Ah.. tis true.  The script defaults to converting the meteoalarm.eu output from UTF-8 to ISO-8859-1 for use in the template sets.
If you're running your non-template site in UTF-8, then changing
$charsetOutput = 'ISO-8859-1';        // default character encoding of output
to
$charsetOutput = 'UTF-8';        // default character encoding of output
will leave the output in UTF-8 for you.
Best regards,
Ken
Offline Cavaliere
    • Ombarcellonapg
« Reply #7 on: January 10, 2019, 06:33:33 AM »
Hi everyone,
I finally found the correct discussion for my problem, I can not display accented characters on the meteoalarm script, I tried to put both UTF-8 and also ISO-8859-1 wh
Resolved ;)
« Last Edit: January 10, 2019, 06:41:45 AM by Cavaliere »
Offline Cavaliere
    • Ombarcellonapg
« Reply #8 on: January 11, 2019, 02:34:22 AM »
Good morning guys,
I continue to have problems with the letters accented in Italian on this script. (è à òù) why?
« Reply #9 on: January 11, 2019, 10:50:07 AM »
You are running the correct version of the script, and have the output set for UTF-8.
The problem comes from the source of the data at https://www.meteoalarm.eu/it_IT/0/0/IT018-Sicilia.html
They are reporting
Non ? richiesta alcuna attenzione speciale
on their page.  It's likely that someone at the meteoalarm or the Italian weather bureau used ISO-8859-1 instead of UTF-8 for posting that message.  The script cannot back-convert to remove their error.  Sorry...
Offline Cavaliere
    • Ombarcellonapg
« Reply #10 on: January 13, 2019, 03:57:11 AM »
They are reporting
Ok thanks so much so it's not a mistake that depends on the script, but on the meteoalarm site itself.
While I do not understand how to update the alerts for now in my region in Sicily I see an orange alert but the script does not report the image with the warning why?
« Reply #11 on: January 13, 2019, 05:05:24 PM »
It may have just been a cache issue -- I see on your page
inizio validit? dal 13.01.2019 12:00 CET fino a 14.01.2019 23:59 CET
Vento  Livello di pericolo: Giallo
english: Wind gusts >30kt BE AWARE, keep up to date with the latest weather forecast. Expect some minor disruption to outdoor activities italiano: Raffiche >30kt STARE (RIMANERE) ATTENTI. Tenersi aggiornati con le previsioni del tempo più recenti. Aspettarsi alcuni disagi minori per le attività all'aria aperta.
and the yellow caution image for alerts.
The default in the get-meteoalarm-warning-inc.php is 300 seconds (5 minutes) for the cache lifetime.
