Did you find that the ecowitt.net showed the distance yet the console did not?
Yep. ecowitt dashboard shows each strike distance fine, as does the API through CMX. It does it on both consoles, so there's a small bug in there somewhere. I think the count has a bug too, it should be resetting each day or something?! If by some chance I get lucky with Spanish plumes or massive MCS' during the Summer, the count might end up being big enough not to fit on the screen.
I also spotted something new; click the up/down arrows 4 times from the main screen - there's a new one there. Not sure how I missed it.
Oh well spotted in the new menu - I had not seen that and its something I have been asking for.
If you have multiple soil sensors you cannot easily see the data on the console and need to use either WS-View (GW1000) or ecowitt.net
I like this view as it sticks and shows all the extra sensor (temp/AQM/Soil and lightning) data in one view that stays until your return it to normal mode.
In terms of the strike count, I have only seen one so I cannot tell, but are you saying that its cumulative?
If I get a new strike today I was assuming that the last strike time/day would update to the latest measurement and that the strike count would update/reset and start counting the new strikes only
Will need to feed that back as well if so.
