Author Topic: Wifi Logger 2 SD  (Read 816 times)
Offline jonathany70
Wifi Logger 2 SD
« on: January 16, 2021, 10:33:59 AM »
Hi, I just received my WiFi Logger 2 SD and new Vantage Pro2+. I previously had an Oregon Scientific station for about 7 years logging via usb to a Pi.
I have the WiFi Logger set up ok.
Mine has an SD Card slot - so I popped a spare 16GB card in there. However I wondered if this is used at all yet with the firmware - there is no mention of it in the manual or web config.
Re: Wifi Logger 2 SD
« Reply #1 on: January 16, 2021, 11:04:34 AM »
"Wifilogger2 has an SD card slot for future implementation in future firmware updates."
Offline jcookjr82
« Reply #2 on: January 26, 2021, 03:18:09 PM »
I just bought a Logger v2 for a second station I plan on installing at our cabin. I wonder if this could ever be programmed to store backup data?
Davis Vantage Vue (Brentwood, CA KCABRENT8 and Arnold, CA KCAARNOL99)
Davis Vantage Pro2 (Lakehead, CA KCALAKEH52)
Offline jonathany70
« Reply #3 on: January 30, 2021, 06:13:11 AM »
You might be better off also setting up a device like a raspberry pi with a USB drive attached, and it can provide a ftp server for the WiFilogger to export to (or you can subscribe to the MQTT option). Then the data is readily accessible. Actually I use weewx .
