Author Topic: Weewx with new Lacrosse 330-2315?  (Read 3492 times)
Offline Boston4
« on: September 20, 2017, 04:41:40 PM »
I report to CWOP and APRS and need to send data to these other services.
Does anyone know if this model is compatible with Weewx or other third party software?
It's not in the weewx supported hardware list, but I wanted to see if anyone had any luck with it anyway.
Thank you!
Offline Boston4
Re: Weewx with new Lacrosse 330-2315?
« Reply #1 on: October 19, 2017, 08:27:35 PM »
Yes, it will, by setting up a RPI as a bridge, and sniffing data packets using the "interceptor" driver.
Offline tebeve
« Reply #2 on: February 05, 2018, 04:00:49 PM »
I'm trying this very same thing and coming up short on the interceptor driver config part. Would you be so kind as to share what you did to get it working?
Thank you!
Also, sorry for the (kinda) duplicate question... I PM'd you before I found this post as I saw in a different thread that you had mentioned being able to get this working.
Offline vinceskahan
    • home site
« Reply #3 on: February 06, 2018, 09:42:01 PM »
A little confused - you'll probably get much better response in the weewx google group, although I know a lot of those folks pop in here too.
WeeWX sites:
  Davis VP2+DFARS to a pi4
  EcoWitt GW1000, WH32 outdoor T+H, multiple WH31 indoor T+H, WH51 soilMoisture (docker)
  Davis AirLink (inside)
  PurpleAir (outside)
Home site:        https://www.skahan.net/
Wunderground: KWAFEDER15
PWS:                KWFEDER15
CWOP:              CW6881
