Thanks SnowHiker!
The option --dump is not available with my hardware. All time settings are fine
I see this errors in the log:
Mar 8 20:05:46 raspberrypi weewx[20343]: cheetahgenerator: Generate failed with exception '<type 'exceptions.TypeError'>'
Mar 8 20:05:46 raspberrypi weewx[20343]: cheetahgenerator: **** Ignoring template /etc/weewx/skins/Weather34/w34charts/chartdata/result.csv.tmpl
Mar 8 20:05:46 raspberrypi weewx[20343]: cheetahgenerator: **** Reason: unsupported operand type(s) for +: 'float' and 'NoneType'
Mar 8 20:05:46 raspberrypi weewx[20343]: **** Traceback (most recent call last):
Mar 8 20:05:46 raspberrypi weewx[20343]: **** File "/usr/share/weewx/weewx/cheetahgenerator.py", line 332, in generate
Mar 8 20:05:46 raspberrypi weewx[20343]: **** fd.write(str(compiled_template))
Mar 8 20:05:46 raspberrypi weewx[20343]: **** File "/usr/lib/python2.7/dist-packages/Cheetah/Template.py", line 1045, in __str__
Mar 8 20:05:46 raspberrypi weewx[20343]: **** rc = getattr(self, mainMethName)()
Mar 8 20:05:46 raspberrypi weewx[20343]: **** File "_etc_weewx_skins_Weather34_w34charts_chartdata_result_csv_tmpl.py", line 251, in respond
Mar 8 20:05:46 raspberrypi weewx[20343]: **** TypeError: unsupported operand type(s) for +: 'float' and 'NoneType'
i read that this can be caused by a sensor beeing offline. As the other reports are fine, i will wait till tomorrow morning to see if this solves on its own
Marc
