Weather Software > WeeWX Software
SDR - Configure Weewx for Ambient and Accurite Sensors?
(1/1)
Fatboy:
Maybe this is documented and I missed it.
Ambient WS-2000 running 915M and Accurite sensors on 433M. Accurite covers a couple sensors, one being newly insulated/heated chicken coop.
Can cmd = support both, 2 cmd entries under SDR? Work-arounds? Rather not run 2 weewx instances.
Sandwiching into belcher and/or weather34 should be fun (still working on getting rtsp cam to show somewhere besides zoneminder ;~(>
Still like WU (10 day) forecast vs Windy - shows time of when rain/cold front etc will hit, seems like a critical forecast piece to me.
Thanks for any help/ideas/suggestions.
weather.texnet.com - hardly ready for prime time but I'm having fun, as time allows.
watsonm:
Are you running SDR or rtl_433 to pick up the data (or something else)
I use rtl_433 and in the config you can set frequencies it will poll in turn . This mean you could have 915Mhz for a period and then 433Mhz. If most of your sensors are on one
frequency you can configure 5 units of time on that frequency and 1 unit on the other. (sort of time slicing!)
Will explain further if required....
Fatboy:
Same here, rtl_433.
weewx config or time slicing or ??? detals would be helpful!
TIA
