Weather Station Hardware > Blitzortung
Station List Not Showing
(1/1)
Silversword:
Hi All,
I just updated my FW to 9.4. It seems to be working as I saw it in the Station List section on the Blitzortung site.
But now I cannot make it come up on my station status on my FF browser. All I get is:
Nothing is clickable.
How can I get my browser to see the settings?
Hope a solution or recommendations will be welcome.
Aloha,
--Stan Y.
   Maui, Hawaii
Cutty Sark Sailor:
Stan, try deleting your browser cache????
Mike
Silversword:
Mike,
I did that with no luck.
Thanks for the suggestion.
Aloha,
--Stan Y.
   Maui, Hawaii
Silversword:
Hi All,
I got it working.
I did a soft re-boot button on the system and that worked.
If it did not then, I would have done a hard re-boot by unplug the power.
At least it is now working and now to see the setups.
Talking about Setups. What is a good starting point with Amplifiers and whether to go Manual or Automatic settings and what level of the Tracker box.
Thanks again for any suggestions.
Aloha,
--Stan Y.
  Maui, Hawaii
miraculon:
I had this problem back in the v9.2 days, but the newest just released versions seem to be OK.
This was back when my connection to the detectors was via a WiFi bridge, now I have a buried Ethernet cable running out to the garage. Not sure if this had anything to do with it, but it could be related. I had a lot of problems with the bridge setup, which is why I went through the trouble of burying the cable.
