Author Topic: Wind Gust help  (Read 1249 times)
Offline mkutche
    • GosportWx.com
Wind Gust help
« on: July 03, 2019, 03:26:23 PM »
Ok so at 3:53AM this morning my weather station had a glitch where it said it recorded 112mph wind gust lol... I use CumulusMX how do I fix this??
Mike K.
Gosport, Indiana
Re: Wind Gust help
« Reply #1 on: July 03, 2019, 05:01:26 PM »
How do you know it is a Cumulus MX issue and not the anemometer hardware or the console of the station? That WH1080 must be getting up there in years and maybe it should be replaced. How long have you had it? And has it ever been serviced? When was the last time you changed the batteries? The WH1080 is known for sometimes getting its memory messed up from time to time and needs to be cleared. I've seen other people complain about the same thing and the were running WeeWx with their old WH1080. That is why i think the culprit is not Cumulus MX.
Online PaulMy
Re: Wind Gust help
« Reply #2 on: July 03, 2019, 05:17:49 PM »
The records received by Cumulus from the station are kept in the various xxx.ini files in your \data folder.  Unlike Cumulus 1, in CumulusMX you will need to edit that erroneous data manually in those files (with CumulusMX stopped).
You may also want to edit the Jul19log.txt log file, as well as dayfile.txt if the bad data shows up there after the midnight rollover.
You might consider setting the Spike Removal in the Calibration Settings to eliminate unreasonable data coming from the station.
Offline mkutche
    • GosportWx.com
Re: Wind Gust help
« Reply #3 on: July 03, 2019, 07:12:17 PM »
Ok I will edit the data this is the 1st time this ever happened lol
Mike K.
Gosport, Indiana
Offline mkutche
    • GosportWx.com
Re: Wind Gust help
« Reply #4 on: July 04, 2019, 10:43:00 AM »
I fixed everything in the data folder but it still saying Gust Month: 111.7 mph July 3
« Last Edit: July 04, 2019, 11:11:54 AM by mkutche »
Mike K.
Gosport, Indiana
Online PaulMy
Re: Wind Gust help
« Reply #5 on: July 04, 2019, 11:13:25 AM »
Where does it say Gust Month: 111.7 mph July 3?
Offline mkutche
    • GosportWx.com
Re: Wind Gust help
« Reply #6 on: July 04, 2019, 11:23:34 AM »
here: http://prntscr.com/oalrgx
ok I fixed it
« Last Edit: July 04, 2019, 11:44:51 AM by mkutche »
Mike K.
Gosport, Indiana
